Push Rods #2922005
05/13/21 08:53 AM
05/13/21 08:53 AM
MN
JERICOGTX Offline OP
MN
I need to order new push rods for my 499, since I'm switching to T&D rockers, and need Ball/Ball pushrods now. I know Smith Brothers, Manton, and Trend are a few places, but which one is best? Don't want to wait forever for a set. Thinking 3/8" .120 wall, or similar.
Thanks.
69 GTX 68 Road Runner
Re: Push Rods [Re: JERICOGTX] #2922020
05/13/21 09:13 AM
05/13/21 09:13 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
ALL GOOD, i always use smith bros, but they all good
....BAD A$$ STREET CAR.....
Re: Push Rods [Re: n20mstr] #2922022
05/13/21 09:21 AM
05/13/21 09:21 AM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
Yep.
They are all good
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Push Rods [Re: B3422W5] #2922023
05/13/21 09:27 AM
05/13/21 09:27 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have used all three. My preference is Manton..
Re: Push Rods [Re: Al_Alguire] #2922062
05/13/21 11:17 AM
05/13/21 11:17 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I have only used Smith Brothers.
However I have used them several times and always been pleased.
Re: Push Rods [Re: 340Cuda] #2922069
05/13/21 11:37 AM
05/13/21 11:37 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
I just ordered a set from Smith Brothers. Took a week to get them.
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: Push Rods [Re: Al_Alguire] #2922079
05/13/21 12:05 PM
05/13/21 12:05 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
up iagree
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Push Rods [Re: JERICOGTX] #2922091
05/13/21 12:39 PM
05/13/21 12:39 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I used Manton's Stage 5 - 7/16ths pushrods in my 493" along with a custom set of T&D's spec'd by B3 Racing along with their geometry correction kit. The result is the smoothest running/rev'ing RB I've owned it 4 decades.
Re: Push Rods [Re: JERICOGTX] #2922094
05/13/21 12:49 PM
05/13/21 12:49 PM
gregsdart Offline
gregsdart  Offline
Jeff i have a couple of sets of 3/8 heavy wall ball to ball pushrods for an indy / RB block combo. If interested let me know. Here is what i have
8-9.82 long
8-9.87
7-9.224
9-9.258
17-9.100
Re: Push Rods [Re: W.I.N. Racing] #2922095
05/13/21 12:49 PM
05/13/21 12:49 PM
up iagree
iagree Me To up
I have had issues with Smith Bros quality on their high end race pushrods, they don't make them as good as the Mantons are twocents work
Manton custom makes each set, no mass produced shelf stock and no cheap parts either twocents
Re: Push Rods [Re: gregsdart] #2922096
05/13/21 12:51 PM
05/13/21 12:51 PM
MN
MN
I need them for my Low Deck, and flat tappet cam, but might be interested in a set for my INDY block, and -1 heads.
Re: Push Rods [Re: jbc426] #2922100
05/13/21 12:53 PM
05/13/21 12:53 PM
MN
MN
Originally Posted by jbc426
I used Manto Stage 5 - 7/16ths pushrods in my 493 along with a custom set of T&D's and a B3 Racing geometry correction kit. The result is the smoothest running/reving RB I've owned it 4 decades.
Curious about the B3 Geometry correction kit? Tell me more.
Re: Push Rods [Re: JERICOGTX] #2922117
05/13/21 01:51 PM
05/13/21 01:51 PM
gregsdart Offline
gregsdart  Offline
Jeff i put the lengths in the post above.
Re: Push Rods [Re: JERICOGTX] #2922120
05/13/21 02:10 PM
05/13/21 02:10 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
http://b3racingengines.com/
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Push Rods [Re: pittsburghracer] #2922393
05/14/21 10:12 AM
05/14/21 10:12 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
My last go around was with Manton and I'm very please with their service. One thing you should consider if you are building/engineering the engine is restricting oiling upstairs via the pushrods. When I mapped-out the single shaft geo on my single shaft TD system I had sleeves with the .750 hole offset +vertically with 'bush-up' to the OEM stand diameter which is .875"? ish which helped geometry. Know too that there was IIRC about .015" more lift at the valve if you used the longest acceptable pushrod.
Re: Push Rods [Re: HardcoreB] #2932046
06/10/21 04:42 PM
06/10/21 04:42 PM
Alabama
W
WarEagle1 Offline
WarEagle1  Offline
W
Alabama
Smith Brothers is good to work with. They had no problem making single intake and exhaust pushrods for me as a sanity check (Gen II Hemi hyd roller setup) and I ordered the balance of the set afterwards (if length is in question).
Re: Push Rods [Re: WarEagle1] #2932051
06/10/21 05:00 PM
06/10/21 05:00 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
I've used Smith Brothers, Trend, Comp cams and they all seem like good parts. The current set we just installed in the 540 are Manley 3/8 .135 wall. Have not run it yet but they are nice looking pushrods as well.
Re: Push Rods [Re: cl440] #2932059
06/10/21 05:43 PM
06/10/21 05:43 PM
an8sec70cuda Offline
I've used both Manton and Smith Brothers. Both have great products and easy to deal with. It's a tossup IMO.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Push Rods [Re: an8sec70cuda] #2932096
06/10/21 08:07 PM
06/10/21 08:07 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I've used Trend in the past, they are nicely made. They make for many other companies as well.
An engine builder friend has been using a local company here in Oz, they use Smith Brothers parts and assemble them here. Also a nice looking push rod.
I don't think you'll go wrong with Trend, Smith or Manton to be honest. I think a lot of preference comes from the relationships people have with the company in question.
Alan Jones
Re: Push Rods [Re: JERICOGTX] #2932110
06/10/21 08:53 PM
06/10/21 08:53 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I prefer Manton. I would suggest not using 3/8” unless space is an issue. Intake ports can be in the way, and require a thin pushrod, but I can’t think of any reason not to run 7/16” on the exhaust side.
