oil leak #293181
04/19/09 06:45 PM
04/19/09 06:45 PM
san diego,ca
rtrag Offline OP
rtrag  Offline OP
san diego,ca
I have a 318 that seems to be leaking oil from the dipstick. This only happens after a run on the highway.Can you have too much oil pressure?
Re: oil leak [Re: rtrag] #293182
04/19/09 06:49 PM
04/19/09 06:49 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Oil pressure won't cause that. Do you have a PCV and breather setup?
Re: oil leak [Re: stumpy] #293183
04/19/09 06:52 PM
04/19/09 06:52 PM
san diego,ca
rtrag Offline OP
rtrag  Offline OP
san diego,ca
I do have a pcv valve.Should I replace it?
Re: oil leak [Re: rtrag] #293184
04/19/09 06:57 PM
04/19/09 06:57 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Should have a pcv in one side and a breather in the other so it can breathe.
Re: oil leak [Re: MoparforLife] #293185
04/19/09 07:03 PM
04/19/09 07:03 PM
san diego,ca
rtrag Offline OP
rtrag  Offline OP
san diego,ca
All there is in the other valve cover is a cap.What type of breather are you refering to.
Re: oil leak [Re: rtrag] #293186
04/19/09 08:06 PM
04/19/09 08:06 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
One of the valve covers has to have a vent that may go to air cleaner housing or straight into atmosphere. It's taller than a flat cap for sure, and usually can have fiber filling that you can see through small holes.
Re: oil leak [Re: buildanother] #293187
04/19/09 10:41 PM
04/19/09 10:41 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
A parts store might have a breather that will replace that cap. You have to have air coming in the valve cover opposite the one with the PCV in it for the system to work. Which is why you need a breather.
