74 'cuda front grill to bumper filler??? #293137
04/19/09 06:12 PM
04/19/09 06:12 PM
Temple, Texas
scoutsr2 Offline OP
scoutsr2  Offline OP
Temple, Texas
anyone know if this piece is available? I actually need both the gray rubber filler and the black plastic piece that it screws to and retains the lower part of the grill.
Re: 74 'cuda front grill to bumper filler??? [Re: scoutsr2] #293138
04/19/09 06:37 PM
04/19/09 06:37 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
I may be able to help you in a week or two.
I don't believe that piece is currently available....
HOWEVER....
I'm currently restoring a 1974 Cuda which I intend replacing the stock front bumper with a new reproduction 70 bumper and 70 bumper brackets from AMD.
I'm not sure how it will fit and if the filler piece will still be required to "look right".
If I don't need it, I can help you out possibly.
CHECK OUT MY NEW WEB SITE !
Re: 74 'cuda front grill to bumper filler??? [Re: anlauto] #293139
04/19/09 09:03 PM
04/19/09 09:03 PM
St. Louis, Mo
3
318 Stroker Online content
318 Stroker  Online Content
St. Louis, Mo
HOWEVER....
Alan,
You WILL be able to help in a week or two...
By using the shorter 70 style brackets, the bumper pulls in, and the space where the fillers went disappears...
Re: 74 'cuda front grill to bumper filler??? [Re: 318 Stroker] #293140
04/19/09 11:00 PM
04/19/09 11:00 PM
Temple, Texas
scoutsr2 Offline OP
scoutsr2  Offline OP
Temple, Texas
so what retains the bottom of a 70 grille then?
Re: 74 'cuda front grill to bumper filler??? [Re: scoutsr2] #293141
04/19/09 11:10 PM
04/19/09 11:10 PM
St. Louis, Mo
3
St. Louis, Mo
It sits above the bumper brackets, and bolts to the core support.
Re: 74 'cuda front grill to bumper filler??? [Re: 318 Stroker] #293142
04/20/09 11:52 AM
04/20/09 11:52 AM
Temple, Texas
scoutsr2 Offline OP
scoutsr2  Offline OP
Temple, Texas
so, I don't suppose anyone knows if these items are reproduced? Sure would prefer to use new stuff that is not brittle and battered...
Re: 74 'cuda front grill to bumper filler??? [Re: scoutsr2] #293143
04/20/09 12:02 PM
04/20/09 12:02 PM
St. Louis, Mo
3
St. Louis, Mo
No, they are not being reproduced.
Re: 74 'cuda front grill to bumper filler??? [Re: 318 Stroker] #293144
04/20/09 07:15 PM
04/20/09 07:15 PM
anlauto Offline
anlauto  Offline
The 1970 Cuda header panel is different then the 71-74's. It has large "C" shaped brackets attached to it that go behind the grill and support a metal filler that fills the gap between the bumper and grill.
