Re: A-body 69 big block oil dip stick & tube
[Re: BlueRacer69]
#2915945
04/28/21 12:44 AM
04/28/21 12:44 AM
Posts: 43,615 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
That is the original dip stick and tube on my 69 383 GTS, I found orange on the tube and dipstick handle so I painted it that way when I restored it.
JB Rhinehart, Realist
A-Body's RULE!
[Re: BlueRacer69]
#2917522
05/01/21 11:29 PM
05/01/21 11:29 PM
Posts: 737 Michigan
BlueRacer69
Look at pic, my car was 100%... I thought the dip stick handle was suppose to be painted black, and the tube had a bend in it for a big block a-body car. In the photo your tube looks straight. So are the repo dip sticks & tubes being sold today for a 68/69 big block Dart totally wrong? Also what should the dip stick say on it other then add & full. Should it have a part number on it. Thanks... Can anyone else help out with the questions I've ask? Thank you.
[Re: BlueRacer69]
#2917620
05/02/21 10:53 AM
05/02/21 10:53 AM
Rhinodart
Rhinotruck
Rhinotruck
The tube is definitely bent where the clamp bolts on the motor mount boss, look closer...
A-Body's RULE!
[Re: Rhinodart]
#2918396
05/04/21 11:55 AM
05/04/21 11:55 AM
Posts: 737 Michigan
BlueRacer69
The tube is definitely bent where the clamp bolts on the motor mount boss, look closer... I thought the oil dip stick & tube came out between the engine block and the exhaust manifold not on the outside of the exhaust manifold.
[Re: BlueRacer69]
#2918638
05/04/21 08:42 PM
05/04/21 08:42 PM
Rhinodart
Rhinotruck
Rhinotruck
The tube is definitely bent where the clamp bolts on the motor mount boss, look closer... I thought the oil dip stick & tube came out between the engine block and the exhaust manifold not on the outside of the exhaust manifold. Not on an A-body. Here is another reference pic...
A-Body's RULE!
[Re: Rhinodart]
#2930089
06/04/21 04:27 PM
06/04/21 04:27 PM
Posts: 1,611 westerly, ri. usa
440lebaron
westerly, ri. usa
all mopar dipsticks had part numbers on them engine and trans, dont know what numbers are what, some trans even had fluid type
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
