A-body 69 big block oil dip stick & tube #2914937
04/25/21 09:18 PM
04/25/21 09:18 PM
BlueRacer69 Offline OP
Is the oil dip stick & tube on a 69 big block Dart suppose to go between the engine block and the exhaust manifold, or between the exhaust manifold and inner fender? Thanks for the help.
Re: A-body 69 big block oil dip stick & tube [Re: BlueRacer69] #2914987
04/25/21 11:30 PM
04/25/21 11:30 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Look at pic, my car was 100%... frown
JB Rhinehart, Realist
A-Body's RULE!
Re: A-body 69 big block oil dip stick & tube [Re: Rhinodart] #2915102
04/26/21 10:45 AM
04/26/21 10:45 AM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
thats how mine is also..
Re: A-body 69 big block oil dip stick & tube [Re: Rhinodart] #2915623
04/27/21 11:22 AM
04/27/21 11:22 AM
I thought the dip stick handle was suppose to be painted black, and the tube had a bend in it for a big block a-body car. In the photo your tube looks straight. So are the repo dip sticks & tubes being sold today for a 68/69 big block Dart totally wrong? Also what should the dip stick say on it other then add & full. Should it have a part number on it. Thanks...
Re: A-body 69 big block oil dip stick & tube [Re: BlueRacer69] #2915945
04/28/21 12:44 AM
04/28/21 12:44 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
That is the original dip stick and tube on my 69 383 GTS, I found orange on the tube and dipstick handle so I painted it that way when I restored it.
A-Body's RULE!
Re: A-body 69 big block oil dip stick & tube [Re: BlueRacer69] #2917522
05/01/21 11:29 PM
05/01/21 11:29 PM
Can anyone else help out with the questions I've ask? Thank you.
Re: A-body 69 big block oil dip stick & tube [Re: BlueRacer69] #2917620
05/02/21 10:53 AM
05/02/21 10:53 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
The tube is definitely bent where the clamp bolts on the motor mount boss, look closer...
A-Body's RULE!
Re: A-body 69 big block oil dip stick & tube [Re: Rhinodart] #2918396
05/04/21 11:55 AM
05/04/21 11:55 AM
I thought the oil dip stick & tube came out between the engine block and the exhaust manifold not on the outside of the exhaust manifold.
Re: A-body 69 big block oil dip stick & tube [Re: BlueRacer69] #2918638
05/04/21 08:42 PM
05/04/21 08:42 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Not on an A-body. Here is another reference pic...
A-Body's RULE!
Re: A-body 69 big block oil dip stick & tube [Re: Rhinodart] #2930089
06/04/21 04:27 PM
06/04/21 04:27 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
all mopar dipsticks had part numbers on them engine and trans, dont know what numbers are what, some trans even had fluid type
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
