1973 Dodge Charger Isolators tightening #2929884
06/03/21 08:27 PM
06/03/21 08:27 PM
TC, Minnesota
Gabmando Offline OP
Gabmando  Offline OP
TC, Minnesota
I replace the K member and torsion bar cross member isolators with Energy Suspension components.
Factory service manual calls out 50 ft-lb for the cross member isolators.
Where it gets fuzzy is that it appears to call out 75 ft-lb for the torsion bar cross member isolators bolts.
This is the exact verbage:
"Position torsion bar isolator assembly over the hex ends of torsion bars and install two bolts. Torque bolts to 75 ft-lb, and tighten to specified torque".
Does this make any sense? 75 ft-lb seems excessive. Thoughts?
Re: 1973 Dodge Charger Isolators tightening [Re: Gabmando] #2929927
06/03/21 10:19 PM
06/03/21 10:19 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Follow the suppliers instructions after all they made the product and should know them best.
Re: 1973 Dodge Charger Isolators tightening [Re: stumpy] #2929969
06/04/21 02:48 AM
06/04/21 02:48 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
IMHO
is not the same torque down the stock rubber pieces than the Poly ones. Am I wrong thinking this?
Re: 1973 Dodge Charger Isolators tightening [Re: NachoRT74] #2929990
06/04/21 08:53 AM
06/04/21 08:53 AM
TC, Minnesota
Gabmando Offline OP
Gabmando  Offline OP
TC, Minnesota
I agree with you you Nacho. Energy Suspension instructions state to use manufacturer torque settings.
