Re: fresh 440 oil pressure drop
[Re: Hangtowner]
#2929591
06/02/21 07:03 PM
06/02/21 07:03 PM
Posts: 4,848 Memphis
HemiRick
Memphis
I assume you were turning the engine well below 4500 RPM, 10 pounds per thousand RPM is considered fine oil pressure.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: Hangtowner]
#2929763
06/03/21 12:55 PM
06/03/21 12:55 PM
Posts: 25,988 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I think this is a bearing clearance issue and no change to the pressure relief valve setting will really alter things, right? Right; you have a volume issue, not a pressure issue. Was a standard volume pump installed?
