mega block main stud torque values #292871
04/19/09 01:55 PM
04/19/09 01:55 PM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
Can someone please tell me the torque specs for my mega block on the main studs.
I lost the paper that came with them and i know i dont remember.Thanks
Re: mega block main stud torque values [Re: sc301v] #292872
04/19/09 04:32 PM
04/19/09 04:32 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
mine 130lbs.on the main studs with 30w oil or 95lb. with ARP lube side studs 35lb. with 30w. or 25 with lube!
Re: mega block main stud torque values [Re: boatracer572] #292873
04/19/09 04:44 PM
04/19/09 04:44 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
This is what ARP told me for my ARP studs
Hello timothy
Kit # 145-5601 the studs will go in the block hand tight only and with
arp moly lube on the threads and washer torque the nut at 90 ft lbs.
RonF
But not sure what studs you have.
