Where are the $2500 Stroker Kits? #2927744
05/28/21 03:36 PM
05/28/21 03:36 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
So its been how many years since the G3 was introduced......And parts aren't much easier to get......
Re: Where are the $2500 Stroker Kits? [Re: Dragula] #2927812
05/28/21 06:02 PM
05/28/21 06:02 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
"Easy to get" and "Chevy cheap" are two different things...
Modern Muscle Extreme sells rotating assemblies.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Where are the $2500 Stroker Kits? [Re: Dragula] #2927874
05/28/21 09:15 PM
05/28/21 09:15 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
Re: Where are the $2500 Stroker Kits? [Re: RTSE4ME] #2927932
05/29/21 01:07 AM
05/29/21 01:07 AM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Call China..
China is the enemy.
Re: Where are the $2500 Stroker Kits? [Re: Dragula] #2927961
05/29/21 07:55 AM
05/29/21 07:55 AM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
MOPAR MODERN HEMI 5.7L to 6.4L 392CI BALANCED SCAT STROKER KIT
https://www.cleggengine.com/mopar-modern-hemi-5-7l-to-6-4l-392ci-balanced-scat-stroker-kit.html
Re: Where are the $2500 Stroker Kits? [Re: GTS340] #2928020
05/29/21 10:34 AM
05/29/21 10:34 AM
Jamey Offline
Jamey  Offline
Make sure you talk to someone before you order from any of these companies. I just ordered a kit for my 6.1 and I had to check several places before I found someone with all the parts in stock. Pistons have been difficult to get from what I was told. I ended up getting my kit from an ebay store.
Re: Where are the $2500 Stroker Kits? [Re: Jamey] #2928101
05/29/21 01:29 PM
05/29/21 01:29 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
If you only want 392 CID why not just buy a stock SRT 392 short block? They can make/take a ton o power... The cam is really easy to lock out if for whatever reason you want to and very adjustable with just a tiny bit of ingenuity.
If your wanting something really big or powerful I wouldn't use the cheapest kit out there, especially if it's made by eagle...
Re: Where are the $2500 Stroker Kits? [Re: RTSE4ME] #2928274
05/29/21 07:36 PM
05/29/21 07:36 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
Originally Posted by RTSE4ME
cnc motorsports is a good company.. i did not post as i figured that stock must be low ... iagree this ---- > Make sure you talk to someone before you order from any of these companies. I just ordered a kit for my 6.1 and I had to check several places before I found someone with all the parts in stock. Pistons have been difficult to get from what I was told. I ended up getting my kit from an ebay store.
Re: Where are the $2500 Stroker Kits? [Re: Dragula] #2928777
05/31/21 08:41 AM
05/31/21 08:41 AM
Souderton
Taylor Offline
Taylor  Offline
Souderton
https://www.campbellenterprises.com/5.7-hemi-stroker-kits.php For the Build it your self types
https://www.shophemi.com/p-263-392-hemi-stroker-kit.aspx Not 2500, but Arrington is one of the older G3 Hemi specialist
https://www.modernmusclextreme.com/...r-kits-by-modern-muscle-performance.aspx still not 2500 but Dave and the guys are probably the most trusted when it comes to the G3 platform.
2019 A lot of these kits were $2500ish...but times move on and prices go up.
04 Ram 4x2 11.66@ 122 4750LBS ...phat pig Moves for fully loaded truck with NA 345ci Hemi
2020 1320 Challenger....stock daily driver.
