Re: Do stock unported 340 heads flow about the same as stock BB
[Re: ragtop]
#2927501
05/28/21 02:10 AM
05/28/21 02:10 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Here is a list of reported flow numbers, but it's hard to really make a comparison as I can't tell if the big block and small block numbers were flowed with the same machine, procedure, and port radius or not? http://users.erols.com/srweiss/tablehdc.htmIf your comparing stock to stock, then the numbers to look at would be around 0.400" to 0.500" because the stock cams only opened to mid .400 lifts 340 is 0.429"/0.444" lift, 268/276 duration - J head at 0.400" looks to be about 190 cfm, 0.500" maybe 200 cfm? 440 is 0.450"/0.455" lift 268/284 duration - small valve 516 looks to be about 10 cfm better? maybe 200/210 cfm? The 906/452 looks to be about 25+ cfm better, around 215/225 cfm?
[Re: ragtop]
#2927573
05/28/21 10:20 AM
05/28/21 10:20 AM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Depends on what you mean by “about the same”.
The best stock 906 I’ve tested was 20-25cfm better than the best stock X head I’ve tested.
Without looking through my notes, I’d say around 10-15cfm difference would be typical between a 906 and an X.
[Re: ragtop]
#2927653
05/28/21 01:08 PM
05/28/21 01:08 PM
Posts: 201 PA
Scully
PA
Do stock unported 1968-71 340 heads flow about the same as the Big block 906 Heads? Thank you. Through the stock mani, they flow very similar which is why the 68-70 340 has almost the same NHRA HP factor as the 68-69 383.
[Re: Scully]
#2927677
05/28/21 02:05 PM
05/28/21 02:05 PM
Posts: 11,719 Portage,michigan
B3422W5
Portage,michigan
Do stock unported 1968-71 340 heads flow about the same as the Big block 906 Heads? Thank you. Through the stock mani, they flow very similar which is why the 68-70 340 has almost the same NHRA HP factor as the 68-69 383. Isnt the factory weight of the car the motor comes in a consideration as well when factoring?
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#2927726
05/28/21 03:16 PM
05/28/21 03:16 PM
Posts: 201 PA
Scully
PA
Do stock unported 1968-71 340 heads flow about the same as the Big block 906 Heads? Thank you. Through the stock mani, they flow very similar which is why the 68-70 340 has almost the same NHRA HP factor as the 68-69 383. Isnt the factory weight of the car the motor comes in a consideration as well when factoring? Factory weight and HP rating are used to find the car's natural class, NHRA may change that factor higher or lower depending on how well the average car of that combo runs, that's the very simplified explanation. As an example the 68 Barracuda with a 340 was factored to 299 from 275, with the 383 it went down to 295 from 300. so the 68 Barracuda with a 340 would have to weigh 42 lbs more in F/SA @ 10.5lbs per HP which is where they frequently run. Also note that the same cars in Super Stock would have the 383 @ 19 HP more than the 340 where the stock mani is no longer the equalizer.
[Re: Scully]
#2927855
05/28/21 08:11 PM
05/28/21 08:11 PM
Posts: 127 Az
HOT IN AZ
Az
Do stock unported 1968-71 340 heads flow about the same as the Big block 906 Heads? Thank you. Through the stock mani, they flow very similar which is why the 68-70 340 has almost the same NHRA HP factor as the 68-69 383. Isnt the factory weight of the car the motor comes in a consideration as well when factoring? Factory weight and HP rating are used to find the car's natural class, NHRA may change that factor higher or lower depending on how well the average car of that combo runs, that's the very simplified explanation. As an example the 68 Barracuda with a 340 was factored to 299 from 275, with the 383 it went down to 295 from 300. so the 68 Barracuda with a 340 would have to weigh 42 lbs more in F/SA @ 10.5lbs per HP which is where they frequently run. Also note that the same cars in Super Stock would have the 383 @ 19 HP more than the 340 where the stock mani is no longer the equalizer. You can't go off NHRA's numbers as factual. My 72 low compression 340 has a factory rating of 240 but NHRA rates it at 293. Lots of politics involved on HP factors!
