Re: Question about A-body hood scoop studs
[Re: moparwizard]
#2927540
05/28/21 09:02 AM
05/28/21 09:02 AM
Posts: 5,655 Detroit area
6PAX
Detroit area
They used a thin black gasket on the stud between the hood and scoop, You can see what's left of it if you blow up the picture.
Thanks for the help. Do you know if there was anything used between the hood and flange nuts on the underside of the hood as well?
[Re: 6PAX]
#2928001
05/29/21 09:54 AM
05/29/21 09:54 AM
Posts: 77 FL
moparwizard
FL
Thanks for the help. Do you know if there was anything used between the hood and flange nuts on the underside of the hood as well? Sorry ,I don't remember and cant seem to find the pictures I had taken.
