69 dart gts convertable door glass #2926370
05/25/21 07:08 AM
05/25/21 07:08 AM
NY
moparmatt0 Offline OP
NY
Still trying to put this car together can any one tell me the difference in the hard top doors and the convertable door because I have a hardtop doner car and I am trying to get the door glass in the convertable it seems only the glass is different but the vent window assembles are the same in that case I am missing 1 door glass thanks for any help Matt.
Re: 69 dart gts convertable door glass [Re: moparmatt0] #2926390
05/25/21 08:40 AM
05/25/21 08:40 AM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
I used hardtop doors in my convertible. The only differences that I knew of and could tell were the side glass and the holes for the wedge that screws on the jamb. Vent windows were exactly the same that I could tell. The side glass isn’t noticeable until you lay a convertible glass on top of a hardtop and then you can see the slight taper difference on the rear edge.
I actually used 70 doors in my 68, so I had the body guy relocate the lock pin hole for me. I do recall a couple other small differences in the glass stops, but nothing major. Door latches for 68 I do recall being different and had to swap over some parts.
Took some time and a lot of trial and error to get all the sealing edges all lined up and sealing well. I had the car so apart that it was basically like starting new between the glass and convertible top alignment. Factory service manual is key to understanding all the adjustments.
Re: 69 dart gts convertable door glass [Re: njmopar] #2926727
05/26/21 12:37 AM
05/26/21 12:37 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
The doors will physically work but the differences are listed above. 69-72 doors are almost identical. The convertible glass tapers about 3/32' about 10" from the back top. You can use hardtop glass but you have to make sure you roll the window down a bit before closing the door and will rattle and scrape when rolled back up when going down the road, DAMHIK!
JB Rhinehart, Realist
A-Body's RULE!
Re: 69 dart gts convertable door glass [Re: Rhinodart] #2926746
05/26/21 06:49 AM
05/26/21 06:49 AM
NY
NY
The vent windows and frames and regulators are the same is that correct thanks Matt.
Re: 69 dart gts convertable door glass [Re: moparmatt0] #2927110
05/26/21 10:59 PM
05/26/21 10:59 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Yes, 67 is slightly different than 68-72 so as long as you use one of those years you will be ok.
A-Body's RULE!
Re: 69 dart gts convertable door glass [Re: Rhinodart] #2927153
05/27/21 06:38 AM
05/27/21 06:38 AM
NY
NY
Thanks for all the help the dart is getting close it now moves under its own power.
