68 Road Runner reverse dash light location #2927069
05/26/21 08:40 PM
05/26/21 08:40 PM
Mid-Atlantic
Scatransit Offline OP
Mid-Atlantic
I’ve seen a few 68 Runners with the dash reverse Iight mounted high up under dash pad in the area in front of where the tach goes...Is this correct?
[oo]======[oo]
Re: 68 Road Runner reverse dash light location [Re: Scatransit] #2927095
05/26/21 10:23 PM
05/26/21 10:23 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
They go at the bottom of the dash.
You can just see it near/behind the shift knob on my '69.
Same location as my '68 but I don't have a photo showing that one.
Re: 68 Road Runner reverse dash light location [Re: Scatransit] #2927096
05/26/21 10:24 PM
05/26/21 10:24 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
Does your car have an Inland or Hurst shifter?
Re: 68 Road Runner reverse dash light location [Re: formula_s] #2927097
05/26/21 10:25 PM
05/26/21 10:25 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
Treed by topside. Inland shifters don't have a reverse light.
Re: 68 Road Runner reverse dash light location [Re: formula_s] #2927098
05/26/21 10:26 PM
05/26/21 10:26 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I suspect the hole is already there.
Re: 68 Road Runner reverse dash light location [Re: Stanton] #2927136
05/27/21 12:32 AM
05/27/21 12:32 AM
A collage of whims
A collage of whims
Formula, you sure about that ?
I had a '68 Hemi 4-speed RR, 9/30/67 SPD, which would have had an Inland when new.
It was swapped for a Hurst (the aftermarket unit) before I got it in the early '80s.
It had the reverse indicator, wired in just like factory.
I pulled its dash to restore it when I restored the car in the later '80s; nothing indicated it wasn't there from Day 1.
All my other '68s were later SPDs or automatics, no help there...
Re: 68 Road Runner reverse dash light location [Re: Stanton] #2927170
05/27/21 08:08 AM
05/27/21 08:08 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Nope need to drill,
Re: 68 Road Runner reverse dash light location [Re: formula_s] #2927185
05/27/21 09:36 AM
05/27/21 09:36 AM
Mid-Atlantic
Mid-Atlantic
The 2 I've seen were Hurst. I suspect that the light was moved at some point by a prior owner?
Admittedly, I've only seen photographs, so I never was able to investigate further. I was thinking that
maybe they were re-located up high for track purposes, so the driver could easily see when the trans
was in reverse?
[oo]======[oo]
