NHRA Stock eliminator class engine assessory requirements #2926616
05/25/21 07:47 PM
05/25/21 07:47 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
Just curious. Are any of the following required in NHRA Stock Eliminator class...
belt driven water pump
belt driven fan
belt driven working alternator
factory air cleaner
exhaust mufflers
Thank you.
Re: NHRA Stock eliminator class engine assessory requirements [Re: ragtop] #2926631
05/25/21 08:20 PM
05/25/21 08:20 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
belt driven fan
factory air cleaner
exhaust mufflers
Thank you.
AIR CLEANERS
Optional. If used, air cleaner must be OEM automotive or retain
OEM configuration. Air-cleaner base may be cut or trimmed,
but welding, bolting, riveting, epoxying, or any other form of
fabrication is prohibited. Ram tubes, velocity stacks, or non-stocktype base plates or ducting prohibited. Cooling holes prohibited in
radiator side panels, etc. Factory air cleaners and/or scoops that
fit through hood must be affixed to carburetor as per OEM only.
EXHAUST SYSTEM
Optional. Adaptor plates, port plates, and header plates
prohibited. Pan evacuation systems prohibited. Turbo
applications, aftermarket header permitted – turbo must be
located in engine compartment. Mufflers and/or maximum
decibel levels may be enforced at certain facilities, according to
any local ordinances that may be in effect. Contact individual
tracks for more information. See General Regulations 1:3.
FAN, GENERATOR, WATER PUMP
Alternator or generator must be engine-driven and functioning.
Belt must be tight enough to drive equipment in a satisfactory
manner without excessive or noticeable slippage. May be
relocated. Aftermarket pulleys permitted. Electrically driven fans
and water pumps permitted. Water pump must bolt on, with no
modifications to block. Use of “smog pump” or air pump for
crankcase evacuation prohibited.
Floyd Lippencott IV
Re: NHRA Stock eliminator class engine assessory requirements [Re: mr_340] #2926661
05/25/21 09:22 PM
05/25/21 09:22 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
Great info. Thanks.
Re: NHRA Stock eliminator class engine assessory requirements [Re: ragtop] #2926780
05/26/21 10:05 AM
05/26/21 10:05 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Of that list, only the functioning alternator is required.
Re: NHRA Stock eliminator class engine assessory requirements [Re: ragtop] #2926951
05/26/21 02:11 PM
05/26/21 02:11 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
If you are going to race NHRA Stock Eliminator you really invest in a rule book.
It could save you a wasted trip to the track.
Good luck and keep us posted on your project.
Re: NHRA Stock eliminator class engine assessory requirements [Re: mr_340] #2926990
05/26/21 03:32 PM
05/26/21 03:32 PM
Idaho
LaRoy Engines Offline
Idaho
Just thought I might reply as to loose/slipping belts running water pumps and alternators. I ran dyno tests and found that with a firm belt tension the engine made more horsepower than when I attempted a loose and slipping belt.
Re: NHRA Stock eliminator class engine assessory requirements [Re: LaRoy Engines] #2926991
05/26/21 03:57 PM
05/26/21 03:57 PM
NE Ohio
DoubleD Online content
DoubleD  Online Content
NE Ohio
The alternator has to be there and have a belt - that qualifies as functioning - most stock racers I knew ran a kill switch on the field as every little bit adds up
Re: NHRA Stock eliminator class engine assessory requirements [Re: DoubleD] #2927039
05/26/21 06:34 PM
05/26/21 06:34 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I found no change, got my 64 Savoy race car in early 90s with basically stock 440 and no alt, just the fan motor. Got tired of charging battery between rounds so I installed a Toyota alt with a big pully, driven off the crank. So expecting a little loss but it ran same number as the last week, maybe just different air so I removed belt and ran same number again not even a hundredth. Ran same number and charged battery, win win. Oh and it charges at 14-15 volts except when idling
This same alt will be going on the 71 E/Stock/A Duster
Re: NHRA Stock eliminator class engine assessory requirements [Re: cudaman1969] #2927253
05/27/21 01:42 PM
05/27/21 01:42 PM
Locomotion Offline
Locomotion  Offline
Functioning or not, maintaining enough and consistent voltage can be a factor in running consistent and predictable ET's. It really wasn't enough, but I have a 50 amp alternator on my Dart Sport and still charged the battery between rounds because the electric water pump & fan were cooling it between rounds.
