Re: 727 Rebuilt after 500 km, debris in pan.
[Re: KrispyKris]
#2926413
05/25/21 10:13 AM
05/25/21 10:13 AM
Posts: 1,115 Usa
A39Coronet
Usa
[Re: KrispyKris]
#2926448
05/25/21 11:49 AM
05/25/21 11:49 AM
Posts: 75,092 A Banana Republic near you.
JohnRR
A small amount of debris is normal , get a thin round magnet , like one found in the later OD's , and stick it in a corner of the pan away from moving servos.
[Re: JohnRR]
#2926459
05/25/21 12:25 PM
05/25/21 12:25 PM
Posts: 3,099 Michigan
A727Tflite
How did you flush the cooler before installing the trans? Did you replace the converter when the trans was rebuilt? Why did you rebuild the trans to start with?
I agree, install a magnet - passenger side rear of the pan. If it runs fine currently, you have nothing to lose by cleaning the pan, adding the magnet and monitor from that point on.
[Re: 6PakBee]
#2926680
05/25/21 10:13 PM
05/25/21 10:13 PM
Posts: 9,149 Tucson, AZ
Ramrod39
My New Title
My New Title
Tucson, AZ
I used to work as a transmission tech many years ago. It was common knowledge to us that 727s were trashy but reliable transmissions. A bit of debris in the pan is common, especially after a rebuild. Don't worry about it as long as it is functioning correctly.
