Whats up with these wrist pins? #2925162
05/21/21 12:26 PM
05/21/21 12:26 PM
gregsdart Offline OP
I bought new 42220 Manley wrist pins last year because i was advised to due to stroke and power increase. They have 14 dyno pulls and seven runs on them. My machinist called and said they were worn enough he didn't want me to reuse them! They supposedly should have been good enough, being .180 wall x 2.93 chrome moly. My CP pins were .150 wall and had over 300 runs on them and still looked good .
I called Trend and they had ONE SET of .205 wall DLC coated pins on the shelf. I bought them. They better hold up. $605 to my door.
I never did get the vacuum up so the motor never saw more than 4 inchs of vac. So my question is why would those Manley pins wear so quickly?
Re: Whats up with these wrist pins? [Re: gregsdart] #2925169
05/21/21 12:41 PM
05/21/21 12:41 PM
A727Tflite Offline
A727Tflite  Offline
What’s your definition of wear?
Re: Whats up with these wrist pins? [Re: A727Tflite] #2925177
05/21/21 12:50 PM
05/21/21 12:50 PM
Texas
Chief Offline
Chief  Offline
Texas
Are you sure it is the pins wearing? I would think the piston pin holes would wear first since it is the softer metal?
Bent pin OK, but worn? Wonder if they were manufactured on the small side..
Just my opinion..
Dave Covey
Re: Whats up with these wrist pins? [Re: gregsdart] #2925181
05/21/21 01:00 PM
05/21/21 01:00 PM
NC
440Jim Offline
440Jim  Offline
NC
That wear is surprising to me too.
In the old days, using 0.150 wall pins was more common, but I changed my mind on that around 2014. And that was with 4.375" bore (lighter pistons).
I plan to use 0.185" wall pins, and have thought about tool steel (H13). Pistons around 575 grams.
Your 0.205" should be very strong.
Re: Whats up with these wrist pins? [Re: 440Jim] #2925213
05/21/21 01:54 PM
05/21/21 01:54 PM
My machinist said there was wear he could feel, and i thought he said there was some fretting? I haven't seen them and never looked that close when i removed them from my other rods and pistons. I went ahead and ordered the better ones. I will post a picture when i get them back.
Re: Whats up with these wrist pins? [Re: gregsdart] #2925244
05/21/21 03:22 PM
05/21/21 03:22 PM
Boise
Moparteacher Offline
Boise
I would send them to Manley and ask them what happened. Very unusual.
Re: Whats up with these wrist pins? [Re: Moparteacher] #2925264
05/21/21 04:00 PM
05/21/21 04:00 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Prolly assembled dry
Re: Whats up with these wrist pins? [Re: Chief] #2925432
05/22/21 10:06 AM
05/22/21 10:06 AM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
Just my opinion..
iagree I'm assuming the rods are bushed which would make the wearing surface on both the rod and piston softer than the pin. Even if a dry assembly were responsible, one would think the pistons and rods would be damaged more than the pin.
