Small Block Intakes, Heads, Blocks question #2925339
05/21/21 10:01 PM
05/21/21 10:01 PM
no mans land
racerbychoice Offline OP
no mans land
Haven’t received parts yet, but bought a complete lot of high-end aftermarket small block heads, blocks, intakes, and stock blocks, etc. It was a good deal so I didn’t hesitate to pass it up, but probably should’ve asked more questions.
Do some of the small block parts interchange with each other? Intakes could be modified or use spacer plates to work from block to block type? How many types of intakes or heads are available? I deal with mostly big block or HEMI stuff.
Re: Small Block Intakes, Heads, Blocks question [Re: racerbychoice] #2925363
05/22/21 12:00 AM
05/22/21 12:00 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Define “high end”....
Re: Small Block Intakes, Heads, Blocks question [Re: J_BODY] #2925364
05/22/21 12:03 AM
05/22/21 12:03 AM
no mans land
no mans land
I did....”high-end...aftermarket”
Re: Small Block Intakes, Heads, Blocks question [Re: J_BODY] #2925365
05/22/21 12:10 AM
05/22/21 12:10 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
come on man the good ones
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Small Block Intakes, Heads, Blocks question [Re: racerbychoice] #2925378
05/22/21 02:38 AM
05/22/21 02:38 AM
As in high end China race stuff or real American race parts?
Did you get a R block with American brand after market race heads?
Or is it a stock block blue printed and ready to assemble with the pistons, crank, bearings, cam and so on? shruggy
I would ask around $6000.00 more for a R3 block with a really good set of ported high end heads and all good race parts in it compare to a stock block with stock big valve heads set up as a decent 600 HP bracket race motor shruggy
Re: Small Block Intakes, Heads, Blocks question [Re: Cab_Burge] #2925400
05/22/21 07:55 AM
05/22/21 07:55 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
How many of any part is hard to say since the small block was first produced back in 64. If you are not familiar with this stuff how did you determine it's a deal you couldn't pass up? May be post some pics and further info on what you have then ask questions.
Re: Small Block Intakes, Heads, Blocks question [Re: Moparite] #2925402
05/22/21 08:06 AM
05/22/21 08:06 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
If its an aftermarket block is it a Ritter block? I would consider a R3 block factory same with any of the W series heads as they were produced by or for Mopar. Indy heads ? perhaps Brodix B1BA ? Edelbrock?
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Small Block Intakes, Heads, Blocks question [Re: racerbychoice] #2925415
05/22/21 09:24 AM
05/22/21 09:24 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Why not list what you have? Not everyone's idea of "high end" is the same.
Re: Small Block Intakes, Heads, Blocks question [Re: justinp61] #2925422
05/22/21 09:46 AM
05/22/21 09:46 AM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Yup, that right there is the key point, what are you KPIs?
For an amateur like myself, something like a combo of R block and W5 heads would fit the label of "high end"...but again, I'm just a DIY guy hanging out in my garage who likes to try out stuff, far and away from a pro shop builder who may be dealing with customers spending thousands of dollars each season building a better motor, right?
Re: Small Block Intakes, Heads, Blocks question [Re: WHITEDART] #2925559
05/22/21 03:28 PM
05/22/21 03:28 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Ahhhh! R5/P7! ...not just some ole truck junk!
Re: Small Block Intakes, Heads, Blocks question [Re: racerbychoice] #2925563
05/22/21 03:49 PM
05/22/21 03:49 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Well , R-3 blocks were available with 340 , 360 or small block Ford mains.
In at least three deck heights as shipped and several options from there.
Let's not forget 59 or 48 degree pushrod angles and siamese or standard cylinder arrangement.
Wet or dry sump ?
Not much interchange between W-7 , 8 and 9 stuff...........and I know there were at least two different types of shaft rocker arrangements for the W-9.............probably more for the W-8 depending on who built them.
I learned all that when building one R-3 , W-9 motor.
Get ready for an adventure if you are planning on screwing together motors out of your parts bonanza.
If you're just going to flip the stuff , there is a market , but it helps to know what you have.
Re: Small Block Intakes, Heads, Blocks question [Re: racerbychoice] #2925744
05/23/21 08:39 AM
05/23/21 08:39 AM
Guitar Jones Online laugh2
Well with the information you provided...
Quote
Yes.
Quote
Yes, some could be.
Quote
A lot.
Quote
I see either a fire sale or much education in your future.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
