Correct Valve Stems Rallye Wheels #2924375
05/19/21 12:41 PM
05/19/21 12:41 PM
fury4speed Offline OP
What’s the correct number for valve stems for a 15X7 1970 rallye wheel , Thanks
Re: Correct Valve Stems Rallye Wheels [Re: fury4speed] #2924843
05/20/21 01:12 PM
05/20/21 01:12 PM
moparx Offline
moparx  Offline
i can't help you with the "correct" number for the stem. however, nothing irritates me more than guys that use, or have installed, a stem that is WAY too long ! tsk
that includes ALL types of wheels, be they steel without caps or covers, trim rings, mags of all kinds, wheel covers, etc.
to me, nothing looks worse than a valve stem sticking out in the breeze. it sticks out like a sore thumb.
i use a stem that is just enough length to be usable with whatever wheel setup is being used.
remember now, this is just my opinion. your mileage will vary.
beer
Re: Correct Valve Stems Rallye Wheels [Re: moparx] #2925141
05/21/21 11:30 AM
05/21/21 11:30 AM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
keep in mind with trim rings they used extensions to make the valve long. The valve itself wasn't long, but an extension was threaded on the valve to extend the valve out far enough outside the ring to help make adding air with a nozzle easier.
While you are at it, if you are setting up wheels and tires for a show car, make sure your tire installer lines up the valve with the Wingfoot on the Goodyear letters on the polyglas tire. devil
Re: Correct Valve Stems Rallye Wheels [Re: Mastershake340] #2925150
05/21/21 11:48 AM
05/21/21 11:48 AM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
2073355 1.5 OAL with plactic extensions in glove box
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Correct Valve Stems Rallye Wheels [Re: 440lebaron] #2925313
05/21/21 08:17 PM
05/21/21 08:17 PM
Thanks for the info , how long are the plastic extensions , the 1.5 mentioned are 1 1/2 long
Re: Correct Valve Stems Rallye Wheels [Re: Mastershake340] #2925316
05/21/21 08:36 PM
05/21/21 08:36 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Wow I had forgotten all about the plastic extensions spank beer
Re: Correct Valve Stems Rallye Wheels [Re: TJP] #2925347
05/21/21 10:17 PM
05/21/21 10:17 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Me too...from a practical standpoint they suck! Worked at a tire store in the early 80s...I remember taking many of them off due to leaks.
Re: Correct Valve Stems Rallye Wheels [Re: Dcuda69] #2925528
05/22/21 01:52 PM
05/22/21 01:52 PM
moparx Offline
moparx  Offline
and replacing the plastic ones with genuine "dill" brand metal extensions. up
we did that on an ongoing basis when i worked at a body shop from 1968-1972.
beer
