Re: regular 440 v/s six pack lifters
[Re: mgoblue9798]
#2924988
05/20/21 07:38 PM
05/20/21 07:38 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
VL 72 f/s VL72RH what is the difference? Can the RH( listed for six pack and hemi application ) be used in regular 440 with no problems? I don't think so. The 6bbl cam used a "low taper" design.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 3hundred]
#2925000
05/20/21 08:16 PM
05/20/21 08:16 PM
Posts: 43,205 Bend,OR USA
Cab_Burge
VL 72 f/s VL72RH what is the difference? Can the RH( listed for six pack and hemi application ) be used in regular 440 with no problems? I don't think so. The 6bbl cam used a "low taper" design. The 1970 and 1971 Street Hemi motors used the same lifters and low tapered lobe design as the 1969 1/2 , 1970 and 1971 six pack 440 motors used. Buy the proper lifters for your motor to match the cam lobes
