Re: lifters full of oil,cant set preload? easy fix ?
[Re: ogopogo]
#2924361
05/19/21 12:30 PM
05/19/21 12:30 PM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
It doesn't really matter if they are pumped up, what are you using for rocker arms?
Guessing they are adjustable at the pushrod side, so you can figure lifter preload by thread pitch and turns.
[Re: ogopogo]
#2924370
05/19/21 12:37 PM
05/19/21 12:37 PM
INTMD8
Lake Villa Il
On a stock type setup I would set it up with the shaft and a couple of rockers (to measure an intake and an exhaust)
Bring to zero preload on base circle, zero dial indicator on pushrod side and torque down the shaft.
You can watch the lifter bleed down with spring pressure against it and dial indicator movement = lifter preload. (at which point you can order correct length pushrods if needed)
Repeat on a few other valves to verify consistent readings and that bank to bank is the same.
[Re: INTMD8]
#2924443
05/19/21 02:39 PM
05/19/21 02:39 PM
Posts: 8,880 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
On a "stock" non-adjustable setup you just install the things and go.
On a set with adjustable rockers you bolt the rockers down with the adjusters backed out. Get each lifter on the base circle and adjust to zero lash (you can do this by spinning the pushrod - when it hits zero it will be tight to turn) then turn the adjuster an additional turn and tighten the lock nut.
Don't worry about the lifters being pumped up, they'll bleed down under spring pressure.
[Re: ogopogo]
#2924492
05/19/21 04:18 PM
05/19/21 04:18 PM
INTMD8
Lake Villa Il
Adjusters are at the pushrods and 3/8-24? If so that's .041 per turn. I would personally go for 2 turns and .080 preload (but I would guess others think that's too much.)
[Re: Moparteacher]
#2924648
05/19/21 09:33 PM
05/19/21 09:33 PM
Posts: 43,225 Bend,OR USA
Cab_Burge
Amount of preload is insignificant until you start floating valves, then it gets serious real fast. If you want to play it safe then less is more. 1/4-1/2 turn is sufficient. A few thousandths is all that's required. I use between 1/8 turn to 1/2 turn preload after getting zero lash with adjustable rockers and pushrod set up 3/8x24 adjusters equal right at .0416 so I use .042 per turn, 7/16x20 equal .050 per turn I like to see between .012 to .025 clearance under the lifter retainer to the pushrod cups cold on iron heads and a little bit more with aluminum heads, say another .006 deeper, with the intake manifold off if you have non adjustable rocker arms order a checking pushrod and use it to determine which length non adjustable pushrods you will need. I would check at least two cylinders, one on each side, and both valves to see if your going to need different length pushrods on one side or not and also if the intake valves need a different length pushrod than the exhaust valves do.
[Re: Moparteacher]
#2924669
05/19/21 10:07 PM
05/19/21 10:07 PM
INTMD8
Lake Villa Il
Amount of preload is insignificant until you start floating valves, then it gets serious real fast. If you want to play it safe then less is more. 1/4-1/2 turn is sufficient. A few thousandths is all that's required. I agree to a point. If you're close on valve to piston you certainly don't want to run more than you need. I prefer to run around .080 and set it up to where it's not on the edge of losing control. Reason I say that is, if you run 1/4 turn, or .010, if the valves bounce on the seats (at all) the lifter plunger hammers it's retainer. (if you've ever seen the clips blown out of them).
