Re: Lares Manual Steering Box
[Re: davenc]
#2923016
05/15/21 10:44 PM
05/15/21 10:44 PM
Posts: 15,348 Omaha Ne
TJP
Omaha Ne
[Re: davenc]
#2923343
05/16/21 11:45 PM
05/16/21 11:45 PM
Posts: 31,021 Oregon
AndyF
Krautrock,
My recollection is fuzzy, but is the PST box made of cast iron and slightly different in appearance than factory? I thought the factory box is cast aluminum.
The Flaming River box is cast iron. PST might have sold the Flaming River box at one time but they now sell the aftermarket aluminum box. I don't know who makes the aftermarket aluminum box, I assume it is an offshore product but I don't know. I think they have been around for a few years. There was a thread over on FABO a couple years back about those boxes. I've never seen one in person myself.
[Re: krautrock]
#2923416
05/17/21 10:42 AM
05/17/21 10:42 AM
Posts: 9,099 Rogue River, OR
Jeremiah
Rogue River, OR
I have a new Lares from Rock Auto in my 68 GTS. It is aluminum and every bit as good as the OEM box I had upgraded to 16:1. Unless I am trying to preserve number I always buy new.
[Re: TJP]
#2923697
05/17/21 10:02 PM
05/17/21 10:02 PM
Posts: 598 NC, USA
davenc
NC, USA
Well, a representative from Lares responded to my questions but didn't completely clear up with the confusion so I may need to talk on the phone to someone. The rep said their two options are the same in appearance, fit, and function with the only difference being one is new and the other is remanufactured. He then went on to indicate the case is cast iron..... Just to check my sanity I went to the garage and put a magnet on my manual box and it does not stick. I have to believe that the remanufactured boxes are based on original MOPAR boxes and hence cast aluminum.
Krautrock, you indicated your PST box is aluminum and weighs 14 lbs. Lares indicates the shipping weight for both new and remanufactured is 14 lbs. Jeremiah indicates his Lares box is aluminum. So I am thinking the Lares rep gave the wrong answer on the case material. Is it possible that an aluminum case box could weigh the same as a cast iron case box? I wanted to avoid a cast iron box on the thought it would add needless weight to the car.
Andy, I will try to find that FABO thread.
TJP: I'm not sure of the condition of my box (last thing to remove). I will say the steering was pretty darn spooky prior to putting the car on jack stands. The LCA pivots had a bunch of play once removed and now that the LCA bushing has been replaced they still have some play (not sure what is normal) but less than before. Idler arm was replaced recently (was clearly bad also) which helped but did not cure the spooky-ness. Pitman seems tight but I decided to just replace everything. I'm not sure how hard it will be to pull the box (BB with headers) and my goal is to avoid doing this twice so I'm not sure if I want to tackle the self rebuild!
Anyway I will try to confirm the case material with Lares over the phone, and update this post for others if I get more clarity.
[Re: davenc]
#2923722
05/17/21 11:11 PM
05/17/21 11:11 PM
Jeremiah
Rogue River, OR
I used a 16:1 box, pn 18831. Looking at rockauto the new 24:1 box is out of stock.
[Re: davenc]
#2924128
05/18/21 08:50 PM
05/18/21 08:50 PM
TJP
Omaha Ne
You may want to verify that the ("spookiness") play is in the box. once verified it is, Step #1 is to disconnect the steering box at either end of the ptiman arm. #2 turn the steering wheel all the way either direction until it stops #3 count the exact number of turns to hit the stop in the opposite direction. ( If i remember correctly it s/be about 5-3/8 turns #4 Turn the wheel back exactly 1/2 the number of turns. 2-11/16or 3/4 turns This will center the worm and sector gears for adjustment. #5 Loosen the locknut on top of the steering box cover several turns while holding the adjusting screw stationary. #6 turn the adjusting screw in just until a slight amount of resistance is felt or the paly is eliminated. BAck the screw up 1/4 to 1/2 turn. #7 while holding the scre stationary tighten the locknut. #8 Reconnect the steering pitman. do not be surprised if the tie rods need adjusting to align the pitman with the splines on the box. the box is now centered and adjusted properly and the steering wheel should be centered. if the play is eliminated you may have to get the ties rods/ toe reset to center the wheel when going straight down the road. There are other adjustments and wern components that will cause the excess play but this one is the most common cause. If you over adjust the sector or do so without it being centered on the worm it will cause a "binding" feeling when going on direction or the other check the factory service manual for adjustment instructions.
