Where to find Grade 8 Sex Bolts, Mating Screws?
#2921695
05/12/21 02:32 PM
05/12/21 02:32 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
I am looking for Grade 8 sex bolts in a 1/2" to 5/8" diameter barrel with a grip range of 3" to 3-1/4".
Prefer to find a tapered seat style for a flush mount.
I can find them in 18-8 Stainless, but I would really like to have Grade 8.
Anyone know any sources for such fastener?
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
Re: Where to find Grade 8 Sex Bolts, Mating Screws?
[Re: hp383]
#2921697
05/12/21 02:35 PM
05/12/21 02:35 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
Anyone know any sources for such fastener? You might try your local bolt supplier and ask for A490 specs. Don't settle for A325.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 3hundred]
#2921702
05/12/21 02:39 PM
05/12/21 02:39 PM
3hundred
Colleyville
Anyone know any sources for such fastener? You might try your local bolt supplier and ask for A490 specs. Don't settle for A325. Wait, tapered seat? You mean flat head? I know of no such thing.
[Re: Pacnorthcuda]
#2921704
05/12/21 02:41 PM
05/12/21 02:41 PM
Posts: 8,395 Highland, MI.
Sunroofcuda
Highland, MI.
Yeah - sex bolts?
Might start with pichunter................
[Re: Sunroofcuda]
#2921719
05/12/21 03:18 PM
05/12/21 03:18 PM
3hundred
Colleyville
Yeah - sex bolts?
Might start with pichunter................ Ah, c'mon, it was probably just a typo. He probably meant 8 sex bots...
[Re: Sniper]
#2921794
05/12/21 06:10 PM
05/12/21 06:10 PM
hp383
State of Confusion
These are what I can find in stainless steel.
However I would like to get them in just standard grade 8 steel.
https://www.mcmaster.com/sex-bolts/barrel-diameter~5-8/head-type~flat/for-material-thickness~3-1-4-3-1-2/
[Re: Sniper]
#2921841
05/12/21 08:15 PM
05/12/21 08:15 PM
Sunroofcuda
Highland, MI.
Nope - you can't. I don't think you can harden stainless, even though it's already hard. No way stainless is grade 8. When you need grade 8, you need grade 8!
[Re: Sunroofcuda]
#2922047
05/13/21 10:40 AM
05/13/21 10:40 AM
Posts: 22,696 Bitopia
jcc
Bitopia
Nope - you can't. I don't think you can harden stainless, even though it's already hard. No way stainless is grade 8. When you need grade 8, you need grade 8! 17-4 Stainless is available and very comparable strength wise to typical grade 8, and far superior to typical grade 2 stainless fasteners. Physical Properties: Melting Point: 2560 - 2625°F (1404 – 1440°C) Density: 0.282 lbs/in3 / 7.8 g/cm3 Modulus of Elasticity in Tension: 28.5 X 106 psi / 197 GPa Mechanical Properties: Condition: Solution Treated (A) Tensile Strength Minimum (psi): 160,000 Yield Strength Minimum 0.2% offset (psi): 145,000 % Elongation in 2” Typical: 5% Hardness: Rockwell B85 Condition: Hardened + Aged (TH1050) Tensile Strength Typical (psi): 200,000 Yield Strength Typical 2% offset (psi): 185,000 % Elongation in 2": 8% Hardness: Rockwell C35 Condition: Aged (H1075) Tensile Strength Typical (psi): 175,000 Yield Strength Typical 2% offset (psi): 165,000 % Elongation in 2": 8% Hardness: Rockwell C37 Condition: Aged (H900) Tensile Strength Typical (psi): 210,000 Yield Strength Typical 2% offset (psi): 200,000 % Elongation in 2": 7% Hardness: Rockwell C45 For reference sake, its likely double the cost of typical SS.
[Re: Hugh Jorgan]
#2922064
05/13/21 11:19 AM
05/13/21 11:19 AM
Posts: 21,823 Kirkland, Washington
Pacnorthcuda
Sex bolts.......am I missing out on something here? Doc should know.... paging doc, paging doc And let’s not forget “mating screws”. Apparently there is a language of love that I never learned.
[Re: Pacnorthcuda]
#2922084
05/13/21 12:16 PM
05/13/21 12:16 PM
Posts: 2,110 Byron, NY
W.I.N. Racing
Byron, NY
Sex bolts.......am I missing out on something here? Doc should know.... paging doc, paging doc And let’s not forget “mating screws”. Apparently there is a language of love that I never learned. That's just redundant...pick one.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: jcc]
#2922087
05/13/21 12:31 PM
05/13/21 12:31 PM
Posts: 6,250 nowhere
Sniper
nowhere
Nope - you can't. I don't think you can harden stainless, even though it's already hard. No way stainless is grade 8. When you need grade 8, you need grade 8! 17-4 Stainless is available and very comparable strength wise to typical grade 8, and far superior to typical grade 2 stainless fasteners. Physical Properties: Melting Point: 2560 - 2625°F (1404 – 1440°C) Density: 0.282 lbs/in3 / 7.8 g/cm3 Modulus of Elasticity in Tension: 28.5 X 106 psi / 197 GPa Mechanical Properties: Condition: Solution Treated (A) Tensile Strength Minimum (psi): 160,000 Yield Strength Minimum 0.2% offset (psi): 145,000 % Elongation in 2” Typical: 5% Hardness: Rockwell B85 Condition: Hardened + Aged (TH1050) Tensile Strength Typical (psi): 200,000 Yield Strength Typical 2% offset (psi): 185,000 % Elongation in 2": 8% Hardness: Rockwell C35 Condition: Aged (H1075) Tensile Strength Typical (psi): 175,000 Yield Strength Typical 2% offset (psi): 165,000 % Elongation in 2": 8% Hardness: Rockwell C37 Condition: Aged (H900) Tensile Strength Typical (psi): 210,000 Yield Strength Typical 2% offset (psi): 200,000 % Elongation in 2": 7% Hardness: Rockwell C45 For reference sake, its likely double the cost of typical SS. Irrelevant if no one makes sex bolts in 17-4 stainless.
