Re: Where to find Grade 8 Sex Bolts, Mating Screws?
[Re: LarryJoew]
#3097593
11/27/22 05:43 PM
11/27/22 05:43 PM
Posts: 11,562 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Certainly not cheap. But a very useful fastener.
If I really wanted to use Grade 8 type materials, I believe I would source the correct Gr8 Socket Head Flat Head Screws and fab the sleeve to the desire length. Wall thickness of the sleeve could be controlled for the desired strength.
4130 solid bar or thick wall tubing would be a good material. Can't imagine that the price per piece wouldn't be cheaper.
[Re: rustbuckett68]
#3098099
11/29/22 02:31 PM
11/29/22 02:31 PM
Posts: 2,075 CA
crackedback
CA
[Re: rustbuckett68]
#3098173
11/29/22 06:30 PM
11/29/22 06:30 PM
Posts: 8,259 fredericksburg,va
cudaman1969
fredericksburg,va
Here I was under the impression that in a shear type of mount, a grade 5 is better, as a grade 8 is too brittle. Grade 8s are more for clamping pressure than shear. I think most stock suspension bolts are grade 5, are they not? Just stirring the pot. Were the old guys wrong in using a grade 5 in shear?l What I was told too, grade 5 for drive studs on axels more elastic, grade 8 has less shear strength, brittle. A guy had one of those tubular front ends with tubular lcas, while turning backing up slowly a 3/4” grade 8 bolt sheared off, car dropped to ground. Seams like a few had done the same so company made a double shear fix
[Re: cudaman1969]
#3098231
11/29/22 11:02 PM
11/29/22 11:02 PM
Posts: 15,357 Omaha Ne
TJP
Omaha Ne
Here I was under the impression that in a shear type of mount, a grade 5 is better, as a grade 8 is too brittle. Grade 8s are more for clamping pressure than shear. I think most stock suspension bolts are grade 5, are they not? Just stirring the pot. Were the old guys wrong in using a grade 5 in shear?l What I was told too, grade 5 for drive studs on axels more elastic, grade 8 has less shear strength, brittle. A guy had one of those tubular front ends with tubular lcas, while turning backing up slowly a 3/4” grade 8 bolt sheared off, car dropped to ground. Seams like a few had done the same so company made a double shear fix HMM never heard the above But with most uhh _____ coming from ______ a grade 8 could be a grade 2. I've seen some scary stuff from over there
