Re: Driveshaft Angle Demonstration
[Re: MoonshineMattK]
#2922228
05/13/21 08:25 PM
05/13/21 08:25 PM
Superfreak
Superfreak
You need a Thompson Constant Velocity Joint
[Re: ]
#2922423
05/14/21 11:40 AM
05/14/21 11:40 AM
Posts: 8,325 fredericksburg,va
cudaman1969
fredericksburg,va
You need a Thompson Constant Velocity Joint Wonder how much they cost and how do they stay clean?
[Re: cudaman1969]
#2922477
05/14/21 02:11 PM
05/14/21 02:11 PM
Posts: 7,497 Minnesota
Hemi_Joel
Minnesota
This is why set set the pinion angle in relation to the centerline of the transmission mainshaft, not to the ground as some have argued.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: jlatessa]
#2922724
05/15/21 08:59 AM
05/15/21 08:59 AM
Posts: 3,089 Michigan
A727Tflite
Then that begs the question; do you set them parallel at rest or at full throttle? Which is more important for stability of the driveline?
Thanks, Joe
Depends on if it’s a race car or street driver. All the hoopla about setting it parallel to the output shaft or to the ground leaves out one consideration, pinion angle is dynamic.
[Re: A727Tflite]
#2922727
05/15/21 09:30 AM
05/15/21 09:30 AM
Posts: 1,318 Ohio
jlatessa
Ohio
Exactly what I was thinking, the car we're putting together now, (a 71 RR w/620 hp 512c.i.), Is primarily going to be street, BUT, with that kind of HP & TQ, should we limit the pinion reaction to suit both uses?
On our other car, (70 465 HP Charger) we use a pinion snubber to control this. I know what some of the consensus is on snubbers, but I'm old school and have had good results so far..
I have some clamps I can use on the forward leafs, which are std. hp leafs.
Thanks, Joe
[Re: Blucuda413]
#2922782
05/15/21 11:22 AM
05/15/21 11:22 AM
A727Tflite
I have never understood phasing can someone please explain?? On a one piece driveshaft, the front and rear weld joints should be welded on so the front and rear u joints are clocked the same. On a multiple driveshaft arrangement - the joints should be clocked the same way. That’s an oversimplified explanation but you should get the picture.
[Re: moparx]
#2922885
05/15/21 04:52 PM
05/15/21 04:52 PM
cudaman1969
fredericksburg,va
Ladder bars and 4 links keeps them close (under power) don’t matter riding around. Ever see a video of S/S springs and Cal Tracs On launch? Tremendous over angle = HP loss (you saw it stop in the vid when over angled). Oh no the dreaded pinion angle debate again!!
[Re: cudaman1969]
#2923519
05/17/21 02:47 PM
05/17/21 02:47 PM
Posts: 288 NW Illinois
MoonshineMattK
NW Illinois
Ladder bars and 4 links keeps them close (under power) don’t matter riding around. Ever see a video of S/S springs and Cal Tracs On launch? Tremendous over angle = HP loss (you saw it stop in the vid when over angled). Oh no the dreaded pinion angle debate again!! Didn't realize there was a pinion angle debate in the past. What were the opposing ideas?
#2923533
05/17/21 03:17 PM
05/17/21 03:17 PM
cudaman1969
fredericksburg,va
Ladder bars and 4 links keeps them close (under power) don’t matter riding around. Ever see a video of S/S springs and Cal Tracs On launch? Tremendous over angle = HP loss (you saw it stop in the vid when over angled). Oh no the dreaded pinion angle debate again!! Didn't realize there was a pinion angle debate in the past. What were the opposing ideas? Now you gone and done it! Maybe after seeing the video Chrysler’s idea of 3 degrees down, then under power straight, WAS a good thing.?!
[Re: cudaman1969]
#2923575
05/17/21 05:10 PM
05/17/21 05:10 PM
MoonshineMattK
NW Illinois
Ladder bars and 4 links keeps them close (under power) don’t matter riding around. Ever see a video of S/S springs and Cal Tracs On launch? Tremendous over angle = HP loss (you saw it stop in the vid when over angled). Oh no the dreaded pinion angle debate again!! Didn't realize there was a pinion angle debate in the past. What were the opposing ideas? Now you gone and done it! Maybe after seeing the video Chrysler’s idea of 3 degrees down, then under power straight, WAS a good thing.?! What angle other than 3deg down has been campaigned?
[Re: A727Tflite]
#2923618
05/17/21 06:48 PM
05/17/21 06:48 PM
A727Tflite
Thanks, Joe
Depends on if it’s a race car or street driver. All the hoopla about setting it parallel to the output shaft or to the ground leaves out one consideration, pinion angle is dynamic. And it depends on what type of chassis setup you have. Ladder bars, Calverts, four link versus plain old springs. All the Chrysler Tech tips back in the day advocated 5 degrees nose down on an automatic trans with SA springs. With the engine in the stock location, etc. Never had to worry about the front angle, just the back.
