What's next!!! #2921423
05/11/21 10:32 PM
05/11/21 10:32 PM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
Has anyone seen this before?
I can't for the life of me think of anything that would cause this. shruggy
The engine ran fine for a few hours then started running badly
and it wouldn't rev at all but it ran just didn't sound pepie.
Then I opened up this can of worms. confused
What the heck is this? flame
Any help with this would be greatly appreciated.
Re: What's next!!! [Re: JoWeTu_6] #2921424
05/11/21 10:38 PM
05/11/21 10:38 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
Wow.... how much overall run time on those parts. (I know you posted a few hours but parts look well used or old).
Parts look well used up. Time to replace.
STOP POTATO HATE!
Re: What's next!!! [Re: Mr PotatoHead] #2921425
05/11/21 10:43 PM
05/11/21 10:43 PM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
Not more than 3 hours total.
I can't explain it. It looks like it just flashed off inside the cap
somehow.
I don't have any vent holes in the cap, that maybe
one problem.
But I don't know for sure.
Re: What's next!!! [Re: JoWeTu_6] #2921445
05/11/21 11:31 PM
05/11/21 11:31 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Years ago I ran an MSD box on an HEI setup and the bushing under the rotor got hot and melted the plastic up good enough that it shut off. Maybe the rotor bushing gave up on you?
Re: What's next!!! [Re: Neil] #2921463
05/11/21 11:59 PM
05/11/21 11:59 PM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
I hope so I have a new cap just need to order another rotor.
But there hard to find it seems.
Re: What's next!!! [Re: JoWeTu_6] #2921478
05/12/21 01:32 AM
05/12/21 01:32 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Had a similar deal on my Chevy pickup (HEI) last year.
Just putting along, then a couple misses, then a few LOUD backfires through the exhaust, then cleared up.
Drove it 5 miles home and started looking it over.
Rotor had exploded at the center contact.
How the thing cleared up & made it home is beyond my understanding.
Replaced cap & rotor - and 2 pooched mufflers - and it's been fine since.
Re: What's next!!! [Re: JoWeTu_6] #2921482
05/12/21 01:40 AM
05/12/21 01:40 AM
vent the new caps up wrench
Mopar use to advice that, drill several vent holes in those early caps, on all the Mopar caps using any of the MSD race boxes thumbs
I would drill 4 1/4 inch holes between every other spark plug wire terminal up Some guys would drill the sides, any thing was better than no holes to vent the air out of the cap shruggy
Re: What's next!!! [Re: Cab_Burge] #2921483
05/12/21 01:49 AM
05/12/21 01:49 AM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
Thanks, I was hoping that was at least one of the solutions. I had been leaning that way
but I wasn't sure if it could have caused my problem. But it looks like a consensus on this thread so
I for one am going with the group on this.
Thank you all for your input it was very helpful.
PS. I don't know how this ting kept running either. shruggy
Re: What's next!!! [Re: Mr PotatoHead] #2921500
05/12/21 08:19 AM
05/12/21 08:19 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Electricity is like water, it goes to the path of least resistance. The spark should want to flow to the plugs into the block where the ground is, looks like it had trouble finding an easy path.
I would be checking my plug wires, and engine grounds. If you know somebody that can use an ignition scope, after you get it running again, have them check it out. A scope is the only way to watch an ignition system work in real time under a load. Kind of a dying art, but nothing is better to diagnose ignition problems.
Re: What's next!!! [Re: jwb123] #2921517
05/12/21 09:13 AM
05/12/21 09:13 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Engine grounds, Engine grounds, Engine grounds !
Re: What's next!!! [Re: FastmOp] #2921657
05/12/21 01:17 PM
05/12/21 01:17 PM
moparx Offline
moparx  Offline
like the saying goes : "you can't have too many [good quality] grounds !" up
the emphasis on the good quality is my insertion. good crimps or solder joints, bare metal to metal attaching points, and appropriate size wire gauge are very important if the grounds are to do the job they need to do !
beer
Re: What's next!!! [Re: JoWeTu_6] #2921862
05/12/21 08:52 PM
05/12/21 08:52 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
Crank trigger?
Re: What's next!!! [Re: Deepockets] #2921903
05/12/21 10:05 PM
05/12/21 10:05 PM
Every crank trigger ignition I've seen had nothing to do with spark distribution work shruggy
Crank trigger using a coil on plug type ignition will cure his distributor cap corrosion problems up scope
Re: What's next!!! [Re: Cab_Burge] #2921907
05/12/21 10:13 PM
05/12/21 10:13 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
I'd asked since my cap and rotor looked similar when I had the phasing off. It had actually had a little bit of the rotor start to melt. I was one tooth off of the rotor belt from where it should have been. Just a thought.
Re: What's next!!! [Re: Deepockets] #2921998
05/13/21 08:40 AM
05/13/21 08:40 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Back in the 90's I had a Chrysler minivan that started going through caps and rotors just like that about every 400 miles. I finally swapped out the distributor to solve the problem. I have no idea to this day what would have caused it.
Re: What's next!!! [Re: JoWeTu_6] #2922051
05/13/21 10:49 AM
05/13/21 10:49 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
If I had to guess, low battery voltage while cranking the engine over....Current goes up as voltage goes down.
Re: What's next!!! [Re: JoWeTu_6] #2922128
05/13/21 02:41 PM
05/13/21 02:41 PM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
I will check the grounds, in fact I will add additional grounds.
Hear is an update.
I took a closer look at the rotor and this is what i found.
It looks like the rotor stood to tall under the cap, I didn't
know that was posible. shruggy
Re: What's next!!! [Re: JoWeTu_6] #2922136
05/13/21 03:10 PM
05/13/21 03:10 PM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
Cap view. It looks like where the cap meets the rotor overheated
and melted.
I don't know if it was because of to much pressure between the two
or a flesh off between the two.
Or could it be a case of miss match of parts shruggy
This is a new cap next to the old one.
Re: What's next!!! [Re: JoWeTu_6] #2922141
05/13/21 03:27 PM
05/13/21 03:27 PM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
Adding to the confusion the dase is vented but I will admit
it may not be enough although I have used thus setup
for a few years know.
I just dont know, the parts may have been defective.
P.S. I've believed I had a comp 9000 series Mallory setup
but when looking up the replacement parts I noticed
none have the screw holes what gives. shruggy
https://www.holley.com/products/ign.../distributor_caps_and_rotors/parts/29749
