RWH to crank? #2921163
05/11/21 01:16 PM
05/11/21 01:16 PM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
My friend had his Runner on a dyno, the model you bolt directly to the wheel hubs. He got 463hp @ 4,238rpm and 570lb ft @ 4,255
What could it be at crank?
440” 727 (Gear Vendor) 8 3/4”
Waiting for the dyno sheet
70 W100 Power Wagon. 318 4-spd
70 Sport Fury 440 2dr HT
71 Duster 340
71 Charger Super Bee - 383/727
72 Charger "Sabotage" - 440/727 - Street/Strip
78 Warlock in beautiful patina
Re: RWH to crank? [Re: HP2] #2921166
05/11/21 01:25 PM
05/11/21 01:25 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
10-30% lost between the flexplate and tire contact patch, depending on how well everything is prepped. A lot of heavy stuff being rotated there.
Re: RWH to crank? [Re: HP2] #2921233
05/11/21 03:23 PM
05/11/21 03:23 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
It all depends on how well the combo works together. My wife's motor made 535HP on the engine dyno. She ran a 10.82 at 3130lb race weight 3 weekends ago and according to Wallace Racing Calculator that's 488 RWHP. 10% loss according to that. I know of a few other engines that were ran on the same dyno and don't produce the ET that I think they "should" run. They are more along the 20-25-30% power loss.
Re: RWH to crank? [Re: HP2] #2921420
05/11/21 10:22 PM
05/11/21 10:22 PM
Every rotating part in the engine and drive train eats HP shruggy
Not all dyno, engine or chassis dyno, read the same either whiney shruggy
Re: RWH to crank? [Re: Cab_Burge] #2921430
05/11/21 10:53 PM
05/11/21 10:53 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
There's no fixed percentage, changes with every vehicle variable, and so many variances between engine dynos and chassis dynos. Sometimes it's fun to do a negative dyno test on the dynojet to see what it approximates drivetrain loss as.
Re: RWH to crank? [Re: Uberpube] #2921474
05/12/21 01:02 AM
05/12/21 01:02 AM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
As mentioned there are a lot of variables to consider. Even so, when I'm looking for a ballpark estimate I use 15% loss for manual transmissions and 20% for automatics.
If a car makes 400rwhp for example, I do the math like this:
manual....400/.85 = 470 engine hp
auto........400/.8 = 500 engine hp
again just an estimate smile
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: RWH to crank? [Re: BigDaddy440] #2921504
05/12/21 08:36 AM
05/12/21 08:36 AM
an8sec70cuda Offline
All dynos are different. I've seen 100 hp difference using the same car on two different dynos.
Mine only made 623 hp at the wheels, but ran 9.54 at 140.4 mph at 3800+ lbs.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: RWH to crank? [Re: HP2] #2921567
05/12/21 11:00 AM
05/12/21 11:00 AM
New York
polyspheric Offline
polyspheric  Offline
New York
RWHP will show different from
tire design, pressure, size
driveshaft angle
ATF fluid temperature
ATF internal parts (TH400 higher than PG, 518 higher than 904, etc.)
stall speed
hypoid angle (9" vs. Dana etc.)
Boffin Emeritus
Re: RWH to crank? [Re: HP2] #2921582
05/12/21 11:22 AM
05/12/21 11:22 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
550 WAG. (Wild Ass Guess) grin
Obviously lots of variables but we've seen about 100 hp differential between rwhp and crank at that level.
I have zero interest in HP ratings anymore. We have used the dyno to tune and optimize a car and know what that translated to for on track performance but not really valid to compare it to others.
'63 Dodge 330
11.19 @ 121 mph
Re: RWH to crank? [Re: BigDaddy440] #2921601
05/12/21 11:58 AM
05/12/21 11:58 AM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
I'd like to see engine dyno's instead of factory numbers, but the
Factory ratings turn out like this, all over the map.
Dynojet 224 inertia testing.
Jeep srt8. 420 rated flwhp auto
Sae rear 367 = .87
78 Ramcharger 440 auto
220 fwhp
121 wheel =.55
Srt10 ram auto
500fwhp sae
360 rwhp=.72
Ferrari 355 challenge manual.
Rated 375 fw
290 rear wheel=.77
Re: RWH to crank? [Re: GY3] #2921606
05/12/21 12:05 PM
05/12/21 12:05 PM
Originally Posted by GY3
[quote=HP2]
iagree
I have learned the hard way that the numbers from a dyno may or may not be accurate whiney This happened several years back when Dram Dan from FL was still alive and had question some dyno HP results on one of my motors from the local Studka engine dyno. I took my 526 C.I. 440 dyno mule from Madras, OR(2500 Ft. elevation) to Klamath Falls, OR(4300 Ft.) to a DTS engine dyno. I made no changes to the motor and it made 100 HP less shock
on the DTS engine dyno that was less than a year old and was calibrated correctly up
I took the motor back and told the dyno operator about the differences between the two dyno and we ended up calibrated it and it lost 100 HP also shock work
There had been conflict between the former dyno operator and the dyno owner so it wouldn't surprise me that he had mess with it before leaving work
My message is don't worry about the net HP and torque, look at the differences between changes you make, if it is getting better your going the right way, if it is losing power go the other way twocents up
Re: RWH to crank? [Re: Cab_Burge] #2921664
05/12/21 01:30 PM
05/12/21 01:30 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My small block lost almost 23% from the engine dyno to a chassis dyno. I wasn't really worried about the numbers, just the tune. It runs just a tick over 110 mph in the 1/8 so it makes somewhere between 300 and 1000 HP. LOL
Re: RWH to crank? [Re: justinp61] #2921688
05/12/21 02:13 PM
05/12/21 02:13 PM
That's easily a 400+ hp combo. grin
CHIP
Re: RWH to crank? [Re: an8sec70cuda] #2921708
05/12/21 02:54 PM
05/12/21 02:54 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Yeah can't really convert, especially with an unlocked auto. You could change it 100HP in either direction with different converters.
Re: RWH to crank? [Re: HP2] #2921727
05/12/21 03:34 PM
05/12/21 03:34 PM
AndyF Offline
AndyF  Offline
My Coronet would make 475 at the rear tires and 550 at the crank when I had the 470 in it. That is with a manual transmission. An automatic transmission can give you some funky numbers on a chassis dyno depending on the converter.
https://www.youtube.com/watch?v=xG3-_YJGdZ8
Re: RWH to crank? [Re: HP2] #2921754
05/12/21 04:57 PM
05/12/21 04:57 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I forgot about those.
My first chassis dyno experience was also on one of the dynapack deals that bolt to the axles.
I can't remember whether Blusmbl took that video or I did, but never in my life have I watched
and listened to a 6 second video SO many times wink
Don't recall the number it made, 4-something, but I do remember the little things I wanted to
experiment with were eye opening and I learned a little bit.
I do recall making more improvements, trying to head back to Matt/the same Dynapack, and Matt telling me to take a hike.
He told me the screens were already flashing warnings during my last test, and that I needed to find a
dynojet. So that was the last time I did that.
He should run it out the back door at the track for MPH, and then weigh it, and then use all the calcuators too.
It's fun bench racing to take a guess, but TBH I've usually just gone by the estimates of folks I respect and left it at that.
Rich H.
Esse Quam Videri
Re: RWH to crank? [Re: ZIPPY] #2921756
05/12/21 05:04 PM
05/12/21 05:04 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
My Dart made 460 hp at 6300 on a chassis dyno, shifting at 63 and 6700 at the line Ran 10.14 at 132 at 3150.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: RWH to crank? [Re: ZIPPY] #2921849
05/12/21 08:28 PM
05/12/21 08:28 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Cooling water issue maybe? My friend has one, it; seen a bunch of 800-1000 rwhp cars.That was the first dyno I got to spend real time on,great for steady state tuning. Dynapack was a out of my financial league when I was dyno shopping.
Re: RWH to crank? [Re: deaks] #2921971
05/13/21 03:58 AM
05/13/21 03:58 AM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
Mick
What's the size of that engine?
71 Duster 340
Re: RWH to crank? [Re: Uberpube] #2922042
05/13/21 10:20 AM
05/13/21 10:20 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
No idea really, He ran the water the whole time.... I don't know what the issue was.
I do remember seeing some red banners flashing across the screen but I don't know what any of it meant.
Maybe a calibration thing? shruggy
Of course it's very possible the guy just decided he hated me and didn't need the money LOL.
If that was true he was a good actor/it wasn't easily detectable.
It was no big deal to find another dyno shop but being that he was a friend of a friend/former classmate of Blusmbl,
I wanted to keep giving him the work. That attempt was probably in 2003 or 4, I haven't spoke to him since/no reason.
Jake's (jake68 here) chassis dyno service is just fine, Gary has like a million years of Mopar experience, BTDT, so the change was not
at all painful.
Rich H.
Esse Quam Videri
