Head stud question #2920881
05/10/21 06:55 PM
05/10/21 06:55 PM
Nebraska
TT5 Valiant Offline OP
Nebraska
What ARP head studs are used with BMP aluminum wedge block with B1 MC heads?
Re: Head stud question [Re: TT5 Valiant] #2920921
05/10/21 08:32 PM
05/10/21 08:32 PM
AndyF Online content
AndyF  Online Content
An engine like that is going to be one of those "figure it out" as you go kind of things. Measure, look in the catalog, make a few phone calls. Good luck, hopefully the parts you need actually exist. Sometimes they don't.
Re: Head stud question [Re: AndyF] #2920960
05/10/21 10:03 PM
05/10/21 10:03 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Wouldn't you just run standard B1 studs? I got my B1MC studs from Koffel.
Re: Head stud question [Re: markz528] #2920984
05/10/21 10:33 PM
05/10/21 10:33 PM
NC
440Jim Offline
440Jim  Offline
NC
That is what I was thinking.
FWIW, I believe you will need studs with about 1" coarse thread (into the block).
16 short studs about 2.75" long
10 long studs about 5.3 to 5.4" long
8 medium studs about 5.1 to 5.2" long
If you run the rocker package with the 5/8 shafts, one pair of rockers on each short shaft per cylinder, the medium studs may hit the underside of the rocker mounting plate. It needs checking.
Re: Head stud question [Re: TT5 Valiant] #2921068
05/11/21 08:58 AM
05/11/21 08:58 AM
NC
440Jim Offline
440Jim  Offline
NC
I have checked two BMP aluminum wedge blocks made this year (2021).
Both have the head bolt/stud holes drilled 1.30" deep. Not the tapped thread depth
Threading a bolt into the hole by hand, just until finger pressure feels the thread start to tighten was 1.14" deep.
So a head stud with 1.0 to 1.1 coarse thread seems about right.
Re: Head stud question [Re: 440Jim] #2921162
05/11/21 01:11 PM
05/11/21 01:11 PM
NC
440Jim Offline
440Jim  Offline
NC
I don't know what lengths this kit has, but ARP says B1 wedge.
Link to ARP
EDIT:
Wow, ARP responded quickly to my queston about the stud lengths in that kit 145-4007
Quote
Thanks for the inquiry. They are 2.750” and 5.000” with 1.000” of both coarse and fine thread.
Best regards,
Zac Kimball
Technical Support
Automotive Racing Products, Inc.
I bought a used set from another racer, and those studs were 2.75", 5.02", and 5.34"
I imagine the 5.0" would work in both "longer" spots, since my head is the same thickness in both.
The 5" will easily clear under the rocker plate of the 5/8 shaft, paired rockers. I est 0.12" clearance. (checked this morning).
My heads are milled to 60cc, so your clearance may vary (including what thickness head gasket you use).
Re: Head stud question [Re: 440Jim] #2921432
05/11/21 10:55 PM
05/11/21 10:55 PM
Nebraska
Nebraska
Thanks for the info I really appreciate the help! I do have the ARP 145-4007 stud kit so I should be fine.
Re: Head stud question [Re: TT5 Valiant] #2921865
05/12/21 08:59 PM
05/12/21 08:59 PM
NC
440Jim Offline
440Jim  Offline
NC
I think you will be fine.
Do you have any way to measure the thickness of the B1-MC heads at the bolt holes?
ie, are they 3.60" or 3.70" , etc.
Do you have your BMP aluminum block yet?
Which rockers are you going to run?
Re: Head stud question [Re: 440Jim] #2921924
05/12/21 10:43 PM
05/12/21 10:43 PM
Nebraska
Nebraska
I dropped everything off at the machine shop May 1st so I can't measure the heads. I will be using T&D paired rockers also. The shop asked me if the studs (145-4007) that I gave him were correct for a aluminum block thats why I asked the question.
Re: Head stud question [Re: TT5 Valiant] #2921968
05/13/21 03:19 AM
05/13/21 03:19 AM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
I have arp 145-4007 supplied by koffels for my b1 originals.
Re: Head stud question [Re: TT5 Valiant] #2921992
05/13/21 08:20 AM
05/13/21 08:20 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
you have to be careful with the studs that go under the rocker stand. Typically they are too short for an alum block, however be careful that when getting longer ones, they dont touch the rocker stand.
....BAD A$$ STREET CAR.....
Re: Head stud question [Re: TT5 Valiant] #2922112
05/13/21 01:36 PM
05/13/21 01:36 PM
NC
440Jim Offline
440Jim  Offline
NC
I am building an engine with B1 original heads, and using those 5/8" shaft rockers (#8013 for B1 original)
The B1-MC use #8027 and a different offset exhaust rocker. Both 5/8 sets use a longer rocker than the one long shaft per head version.
Scott Koffel told me using the 5/8 paired rocker system will require additional pushrod clearancing of the heads.
I am doing a mockup now, and mine definitely needs material removed. Especially the intake holes. Note the intake holes are angled.
Re: Head stud question [Re: n20mstr] #2922169
05/13/21 05:03 PM
05/13/21 05:03 PM
Nebraska
Nebraska
What lifters are you using? I assume you are push rod oiling. Mine is a nitrous combo too, was hopeing to race KOS at Norwalk in July but the machine shop said it will be 3 months until its ready.
Re: Head stud question [Re: TT5 Valiant] #2922370
05/14/21 09:23 AM
05/14/21 09:23 AM
NC
440Jim Offline
440Jim  Offline
NC
I am hoping to use Comp 892 lifters. I am making pushrod clearance to use either all centered pushrod seat lifters (892-C) or centered exhausts with offset intakes (892-L, 892-R)
I am checking to oil hole location in the lifters and the bronze bushings in the block to verify it will work. But I have not completed that work.
Since the block comes without cam bearings, I can't slide a cam in right now. And the lifter bores need final sizing (they come "semi-finished").
Re: Head stud question [Re: 440Jim] #2922379
05/14/21 09:42 AM
05/14/21 09:42 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Can i make a suggestion, helicoil all of your intake bolts. if you don't do it now you will eventually.
Joe
Without Data, you’re just another guy with an opinion.
