E-body convertible belt moulding ? #291879
04/18/09 02:53 PM
04/18/09 02:53 PM
USA
K
krw71ragtop Offline OP
K
USA
Is there supposed to be some type of seal or gasket that goes between the belt moulding trim and the body ?
Re: E-body convertible belt moulding ? [Re: krw71ragtop] #291880
04/18/09 04:51 PM
04/18/09 04:51 PM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
It has been probably 20 years since I took the same molding off my car. There was a thick waxy like material between the molding and the sheet metal, almost like a bees wax. I remember it being gray/black.
Re: E-body convertible belt moulding ? [Re: larry4406] #291881
04/18/09 08:23 PM
04/18/09 08:23 PM
USA
K
K
USA
You have a good memory! It was almost 8 1/2 years ago I took mine apart. I thought I remembered peeling something off there. I have a roll of that gray material you mentioned. looks like I'll be putting it on
Re: E-body convertible belt moulding ? [Re: krw71ragtop] #291882
04/19/09 12:57 PM
04/19/09 12:57 PM
South Texas
badchallenger Offline
Fluff Flipper
Fluff Flipper
South Texas
What is the gray stuff you are talking about and where can I find some ?
I am in the same process of putting on th moulding also.
Thanks!
U.S. Navy Sea Bees (Retired now) U.S. Army Civil Service NDT
Re: E-body convertible belt moulding ? [Re: badchallenger] #291883
04/19/09 01:01 PM
04/19/09 01:01 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
When my grill chrome was done they used a dark grey silicone like bonder, more like liquid nails. 3M trim addhisive. some pieces have plastic clips, some crimp, or slide lock.
They used dabs of it along the way. Not a thick bead across.
Re: E-body convertible belt moulding ? [Re: mark7171] #291884
04/19/09 01:47 PM
04/19/09 01:47 PM
South Texas
Fluff Flipper
Fluff Flipper
South Texas
Well im not sure if the gray stuff just goes where the trim moulding clip holes are or if it goes the entire length also still dont really know what stuff to use. Auto parts guy isint going to know if I tell him gray stuff LOL !
Thanks for the help !
Re: E-body convertible belt moulding ? [Re: badchallenger] #291885
04/19/09 07:35 PM
04/19/09 07:35 PM
USA
K
K
USA
Thanks!
The gray stuff I got at the hardware store when I replaced a window in my house and needed something to help seal it. All I have left is part of the roll but cant remember what it is. It looks and feels like the same stuff as the black 3M strip caulk. Hope this helps.
