Dang, my Mopars are surprisingly heavy.
#2918460
05/04/21 02:27 PM
05/04/21 02:27 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
I finally weighed my cars and was shocked at the numbers.
My '68 A-Body convertible with a full US Cartool chassis stiffening kit, roll bar, stroked aluminum headed 5.9 Magnum, 2004R trans, A/C, BBP wheels with 4 wheel discs and a full TTI 3" exhaust came in at 3750 lbs with a half tank of fuel.
My '70 'Cuda with an aluminum headed 493, Passon 5 speed, Scatter Shield, Dana 60, US Cartool subframe connectors, A/C, Shaker hood, oversized stainless steel fuel tank and full 3" TTI exhaust came in at 4150 lbs with a half tank of fuel.
Both cars have pretty much stock interiors too.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
Re: Dang, my Mopars are surprisingly heavy.
[Re: jbc426]
#2918463
05/04/21 02:31 PM
05/04/21 02:31 PM
Posts: 4,789 Star Idaho
67vertman
Star Idaho
Nice to know. I am surprised that the E body was over two tons. Mine should be close to that, as mine is similarly set up like yours. mine is My '70 'Cuda with an aluminum headed 440, Passon 5 speed, Dana 60, US Cartool subframe connectors, stock hood and fuel tank and full 3" TTI exhaust.
My Monster are real!
Living within your means makes life pretty easy.
[Re: jbc426]
#2918509
05/04/21 04:05 PM
05/04/21 04:05 PM
Posts: 571 Western NC
68Bullit
Western NC
Not sure which scales you used, but I don’t think they’re as heavy as indicated. My B-body weighs in a touch over 3500 last reading I took. It’s a factory a/c car, however the a/c is now gone and I have aftermarket aluminum wheels. But man, if those scales are right, then that’s awfully heavy!
Yeah looks like your over by exactly 1000 lbs on each car. The first numbers on both readings is 1 number over
[Re: 68Bullit]
#2918515
05/04/21 04:15 PM
05/04/21 04:15 PM
Posts: 3,389 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Got another scale nearby? Wouldn't hurt to get a second opinion.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: wingman]
#2918593
05/04/21 06:33 PM
05/04/21 06:33 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
Sounds right. On the ‘70 Cuda.... The shaker adds weight, A/C, Dana is a pig, frame and other connectors add up, big block, 3” TTI fence post take-it-to-the-grave exhaust.... “This is Ed Wogulius's 71 Challenger. 340, 4 spd, t/a fiberglass hood, aluminum heads, cast iron ex manifolds, full interior, no a/c, power steering car ... 3455 lbs without driverLast scale reading pic is with Ed in the car. That is F/R 56.4%/43.6% weight split w/o driver. (scale is just reading rear percentage”
[Re: jbc426]
#2918606
05/04/21 07:09 PM
05/04/21 07:09 PM
autoxcuda
So Cal
Both cars have pretty much stock interiors too. Are those weights with or without driver?
[Re: autoxcuda]
#2918686
05/04/21 10:36 PM
05/04/21 10:36 PM
jbc426
West Coast, USA
These are the weights without driver. You guys are right to suggest I seek out another scale, and I forgot to mention both cars are dynamat'd and insulated too.
[Re: jbc426]
#2918712
05/05/21 12:20 AM
05/05/21 12:20 AM
Posts: 259 n.c.
geo.
n.c.
These are the weights without driver. You guys are right to suggest I seek out another scale, and I forgot to mention both cars are dynamat'd and insulated too. They do sound heavy, are you rolling them on and off the scales? I can't imagine that makes a big difference, just curious. See if you can check the calibration on the scales. Years ago I weighed my '72 Challenger, 440,A833,blow-proof,headers,full exhaust, 15" rallyes, turbo mufflers. Pretty sure it was a little over 3700 lbs.
[Re: jbc426]
#2918722
05/05/21 01:03 AM
05/05/21 01:03 AM
autoxcuda
So Cal
These are the weights without driver. You guys are right to suggest I seek out another scale, and I forgot to mention both cars are dynamat'd and insulated too. Dynamat is very heavy. I doubt it’s too far off. It’s all the stuff that adds up.... on the ‘70: A/C, Dana, steel scatter shield, overdrive, rear steel disk vs lighter drum, big 3” thick exhaust. I bet a 100% complete steel shaker setup weigh more than a steel twin scoop hood. How much bigger is the gas tank? I didn’t weigh the barracuda it at Willow Springs ? I see the background of those pictures.
[Re: Kern Dog]
#2918818
05/05/21 11:24 AM
05/05/21 11:24 AM
68Bullit
Western NC
When I first bought it with the original 318-904-4 wheel drum brakes....3660. First iron headed 440 with 727 and 8 3/4" axle....3750.
Hey Franken, that’s one helluva good lookin 70 model, So, I’ve often wondered the difference in weight between a big block and a small block. Looks like somewhere around 90 lbs?
[Re: autoxcuda]
#2918870
05/05/21 01:16 PM
05/05/21 01:16 PM
jbc426
West Coast, USA
These are the weights without driver. You guys are right to suggest I seek out another scale, and I forgot to mention both cars are dynamat'd and insulated too. Dynamat is very heavy. I doubt it’s too far off. It’s all the stuff that adds up.... on the ‘70: A/C, Dana, steel scatter shield, overdrive, rear steel disk vs lighter drum, big 3” thick exhaust. I bet a 100% complete steel shaker setup weigh more than a steel twin scoop hood. How much bigger is the gas tank? I didn’t weigh the barracuda it at Willow Springs ? I see the background of those pictures. The stainless steel tank is my own design made by Ricks Tanks. It holds an extra 7 gallons. It's 1 inch wider on each side and has an additional sump on the bottom. I have a hunch that the weights are pretty accurate. Both these cars are set up as open road machines, so they are not too low, have overdrive transmissions and are focused on driver comfort on longer trips. The '70 has 3 bulk packs of Dynamat in it, and the '68 has just over 1 bulk pack. I've found that Dynamat type products are good at dampening panel vibration, but an additional layer of a foil covered matting placed over the entire interior and sealed at the edges with aluminum foil with wax backing type duct tape vastly improves the reflection of a significant amount heat, fumes and noise. Used together, the two products can transform a car.
[Re: 68Bullit]
#2919029
05/05/21 08:04 PM
05/05/21 08:04 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Hey Franken, that’s one helluva good lookin 70 model, So, I’ve often wondered the difference in weight between a big block and a small block. Looks like somewhere around 90 lbs? Thank you! The 318 had A/C but the stuff all came off when I put in the 440. If you weigh the compressor, the condensor , A/C lines and belts, that could add up to another 50 lbs or more.
