Re: Brake question
[Re: edison1970]
#2917432
05/01/21 04:35 PM
05/01/21 04:35 PM
Posts: 15,938 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
DOT 5 might be part of the problem. Better for your paint in case of a spill but not for brake feel. Not enough vacuum shouldn't effect travel I don't believe, just hardness of the brakes because less assist.
Facts are stubborn things.
Re: Brake question
[Re: edison1970]
#2917439
05/01/21 04:44 PM
05/01/21 04:44 PM
Posts: 18,160 Mass
DAYCLONA
Mass
I'm having issues with my power brakes on my Barracuda. Factory disc in front and drum in back. Everything is new. Bench bled the master dot 5 used. Bled all four corners until brake pedal was hard. Now I start the car and the pedal pressure drops almost 3/4 down. Could that mean I don't have enough vaccum or the booster is bad? Cam is a Lunati 703. The motor has 15-16 of vaccum at idle. "everything new"....did you set the proper air gap between the booster and master, you need to reset or confirm anytime you rebuild/replace these components, this may be your issue? Mopar's need a minimum of .020 to a max of .060 for proper operation.... MikeG
Re: Brake question
[Re: edison1970]
#2917444
05/01/21 04:52 PM
05/01/21 04:52 PM
Posts: 25,995 Rio Linda, CA
John_Kunkel
Rio Linda, CA
When I depress the pedal when it's running, the pedal goes down 3/4 of the way before the brakes start to work. If the pedal drops with the engine running, vacuum isn't your problem....the booster is working. Have you adjusted the rear shoes for a slight drag when turning the wheel? Loose drum brakes will eat up a lot of pedal travel.
Re: Brake question
[Re: John_Kunkel]
#2917450
05/01/21 05:03 PM
05/01/21 05:03 PM
Posts: 43,307 Bend,OR USA
Cab_Burge
When I depress the pedal when it's running, the pedal goes down 3/4 of the way before the brakes start to work. If the pedal drops with the engine running, vacuum isn't your problem....the booster is working. Every late model power disc brake and 4 wheel drum brake Mopar car I've driven will do what yours is doing the pedal should be really hard to push with the motor off and no vacuum, easy when running and driving, hence the "power brake" name
