Anyone do a lawn tractor transaxle swap? #2917037
04/30/21 04:31 PM
04/30/21 04:31 PM
Connecticut
Ron_M Offline OP
Ron_M  Offline OP
Connecticut
I have a Craftsman rider mower with the Dana D4360 series Transaxle (D4360-140). This series of transaxle has the reputation of being a POS. Most simplest fix might be the input shaft needle bearings but common reports of water intrusion within the gearcase and rusted parts the result thereof are the most common hits using Google.
Has anyone here changed to a Spicer 6800 series (looks like 6800-1 and -2) that the internet "says" might fit? Peerless MST 206-545C another potential swap.
I have not had much luck with Google searches. Looking for someone with actual hands on experience. The only page with anything beneficial is this one: http://www.ssbtractor.com/wwwboard/view_all.cgi?bd=lawn&msg=8269
I already know that a lot of mowers were made by the same manufacturer and just have cosmetic sheet metal and label differences. Most of the mechanicals are the same (even the 'Deeres).
Thanks in advance.
Common sense is a flower that does not grow in everybody's garden
Re: Anyone do a lawn tractor transaxle swap? [Re: Ron_M] #2917040
04/30/21 04:43 PM
04/30/21 04:43 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
I am in the middle of changing the hydro drive on my Cub Cadet. Has about 35 hours on it and it lost its forward motion once it was warmed up. The dealer wanted almost as much to repair is a new one. I decided to see if I could do it. I found a new drive on line from the factory and just started pulling the tractor apart. I should be done this weekend. I cant help on your specific model, but good luck.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Anyone do a lawn tractor transaxle swap? [Re: Ron_M] #2917118
04/30/21 08:36 PM
04/30/21 08:36 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I know a few people that have just changed the fluid and they came back to life, last one I knew of was still going after 4 years shruggy beer
Re: Anyone do a lawn tractor transaxle swap? [Re: TJP] #2917125
04/30/21 08:45 PM
04/30/21 08:45 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Can't help you with the numbers, but back when racing mowers was a thing around here, nearly all the guys swapped in the same transmission and rear axle assembly. Mowers are pretty easy to swap stuff around in, from what I've heard. I'd be willing to bet a search of racing mowers would provide a lot of useful information, those were the guy doing the grass roots swaps. I doubt your going to abuse your lawn mower as much as those guys that raced them did. They swapped in stuff that held up under racing for several seasons, should last forever mowing the grass. Gene
Re: Anyone do a lawn tractor transaxle swap? [Re: TJP] #2917136
04/30/21 09:02 PM
04/30/21 09:02 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Yes change over to 20W50 syn.& they can come back to life.
Re: Anyone do a lawn tractor transaxle swap? [Re: 71GTX471] #2917256
05/01/21 08:36 AM
05/01/21 08:36 AM
Connecticut
Ron_M Offline OP
Ron_M  Offline OP
Connecticut
Thank you all for responding. Unfortunately, the type of transaxle that i have is not a fluid type. They were packed with grease and not sealed properly.
I will look into the racing mower angle.
Thanks :up up
Re: Anyone do a lawn tractor transaxle swap? [Re: Ron_M] #2917394
05/01/21 02:51 PM
05/01/21 02:51 PM
RWG75
RWG75
try mytractorforum.com, have tractor model number
