Power steering pump fitting #2916923
04/30/21 11:05 AM
04/30/21 11:05 AM
Netherlands
72Challenger Offline OP
Netherlands
Hi all. Have 2 cars here (Hellcat 70 Challenger and 68 6.4srt Charger) both in need of custom pressure hoses for the steering pump. Can anybody point in me the right direction to get some correct fittings to screw into the pump? I see some when I google, like from Schwartz but before ordering I thought to check here as it feels like they wont fit good as the thread in the pumps starts only after about 1/2 an inch or so... first part into the pump there's no thread while the Schwartz looks like sort of normal length fittings.
Any input?
Many thanks ahead,
Hans
Re: Power steering pump fitting [Re: 72Challenger] #2916942
04/30/21 11:41 AM
04/30/21 11:41 AM
Toronto Ontario, Can
Glen440 Offline
Glen440  Offline
https://www.bouchillonperformance.com/inc/sdetail/10561
That should be what you are looking for. I got my air conditioning adapter fittings from them.
87 dakota 6.1 hemi
Re: Power steering pump fitting [Re: Glen440] #2917278
05/01/21 09:31 AM
05/01/21 09:31 AM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
If you have a hydraulic shop near you, see what they can do. Probably your easiest bet as most shops not only carry the fittings, but can custom make your hoses as well
