e-body space saver wheel #2915172
04/26/21 12:43 PM
04/26/21 12:43 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
Did all 1970-71 E-body space saver wheels have the extra sixth hole? Or did some cars have the 5 mounting hole wheel?
Thank you
Re: e-body space saver wheel [Re: sbcjd] #2915178
04/26/21 01:01 PM
04/26/21 01:01 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
They all had six holes up until sometime near the end of the 1971 production year. Maybe April 1971 and later they had just the five holes. Maybe someone on the forum could give a more accurate date. I have an original April 1971 spare with just the five holes.
Re: e-body space saver wheel [Re: m46rat] #2915357
04/26/21 06:04 PM
04/26/21 06:04 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
Mine has just the 5 holes. Would the date code on the wheel give any indication as to how many holes it should have?
Re: e-body space saver wheel [Re: sbcjd] #2915598
04/27/21 10:35 AM
04/27/21 10:35 AM
m46rat Offline
m46rat  Offline
Could you post a picture of the valve stem area of your rim that shows the date?
Re: e-body space saver wheel [Re: m46rat] #2915679
04/27/21 12:56 PM
04/27/21 12:56 PM
Ontario, Canada
GVH Offline
GVH  Offline
Ontario, Canada
Mine has 5 holes June 14 /71 build
Re: e-body space saver wheel [Re: GVH] #2915686
04/27/21 01:24 PM
04/27/21 01:24 PM
m46rat Offline
m46rat  Offline
Also, could you post a picture of the valve stem area with date code please. I will dig up mine and post also.
Re: e-body space saver wheel [Re: m46rat] #2915779
04/27/21 04:31 PM
04/27/21 04:31 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I can vouch for GVH's space saver having 5 holes.
I took a few pictures when there once but neglected to take the valve stem area or a clear shot of the center with 5 holes.
I'll do that next time there....
It is original to the car as is the bottle and bracket.
Re: e-body space saver wheel [Re: m46rat] #2915833
04/27/21 06:43 PM
04/27/21 06:43 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
I will try in the next couple of days to get some pictures
Re: e-body space saver wheel [Re: sbcjd] #2915915
04/27/21 10:09 PM
04/27/21 10:09 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Chrysler likely ran out of all those 1970 Rims and thought why not use the 5 hole now instead of the 6 hole. Lot of changes during the 1971 build and a lot at the end of the year.
1971 HEMI E BODY REGISTRY
Re: e-body space saver wheel [Re: hemicar1971] #2916011
04/28/21 08:51 AM
04/28/21 08:51 AM
m46rat Offline
m46rat  Offline
If I remember correctly, the five hole ones don't use the white paint daub on them either, like ALL the other six hole ones did.
Re: e-body space saver wheel [Re: m46rat] #2916205
04/28/21 05:09 PM
04/28/21 05:09 PM
Ontario, Canada
GVH Offline
GVH  Offline
Ontario, Canada
This is what is on my rim by valve stem K11 2 25 55 on mounting flange looks like II X
Will get pic on weekend this is to supplement the info Terry gave above .
Re: e-body space saver wheel [Re: GVH] #2916500
04/29/21 11:21 AM
04/29/21 11:21 AM
m46rat Offline
m46rat  Offline
February 25, 1971, that is earlier that I thought it would be. Maybe this started at the beginning of January, 1971.
Re: e-body space saver wheel [Re: m46rat] #2917382
05/01/21 02:23 PM
05/01/21 02:23 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
My camera is MIA, but the numbers by the valve stem are K11 2 25 5.5 and there is no white paint dab
Re: e-body space saver wheel [Re: sbcjd] #2917505
05/01/21 09:58 PM
05/01/21 09:58 PM
Ontario, Canada
GVH Offline
GVH  Offline
Ontario, Canada
When was your car built ? Mine is June 14 th.
Re: e-body space saver wheel [Re: GVH] #2917510
05/01/21 10:27 PM
05/01/21 10:27 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
A buddy of mine just dug this out of his parts stash, what is it out of? shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: e-body space saver wheel [Re: Rhinodart] #2917581
05/02/21 09:03 AM
05/02/21 09:03 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
That F-78-14 B.F. Goodrich is a good one Jim.
Tire and rim are Ford set-up...good for the 70 Shelby and Boss crowd.
Tire has the all important V-1.
Tire could be switched onto a correct Mopar rim for E-bodies, but is worth as much or more as is on the Ford rim.
Bottle and bracket are reproduction for E-body
Re: e-body space saver wheel [Re: mccannix] #2917619
05/02/21 10:49 AM
05/02/21 10:49 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Thanks! I didn't think it was Mopar, but not well versed on these space savers. Thought the canister looked to good to be original...
A-Body's RULE!
Re: e-body space saver wheel [Re: Rhinodart] #2917645
05/02/21 12:02 PM
05/02/21 12:02 PM
moparx Online content
moparx  Online Content
i junked a 76 newyorker one time that had a space saver spare.
i can't remember the tire size nor the manufacturer, but the bottle and hold down clamp were very close to the blue color of the hold down shown.
i thought it odd that a C-body would have a space saver spare. the size was larger than an F-78, and as the trunk was very well preserved and the car was a low mileage [20something k, but was junked because of severe rust] piece, it sure looked like the space saver was original to the car.
the wheel was never used so the tire was removed [what FUN that was !] and since the wheel was full size, a full size tire was mounted then used on whatever we had going at the time.
beer
Re: e-body space saver wheel [Re: moparx] #2922966
05/15/21 08:22 PM
05/15/21 08:22 PM
Ontario, Canada
GVH Offline
GVH  Offline
Ontario, Canada
not really related but close was looking in trunk yesterday with Terry my hook is 2931101 chrome bumpers .
