Hood Scoop #2915919
04/27/21 10:20 PM
04/27/21 10:20 PM
New Orleans
K
Kaminsky Offline OP
Kaminsky  Offline OP
K
New Orleans
I’m looking for a new lift off hood. I have changed up a few things and need more clearance with my new set up. The new carb and spacers are about 2 inches taller. I only had about 3 inches of clearance in the old hood. How makes some nice lift off hoods? Car runs high 8’s in the quarter at 151mph.
Re: Hood Scoop [Re: Kaminsky] #2915923
04/27/21 10:39 PM
04/27/21 10:39 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Glasstek makes a good hood. A lot better than the others I’ve owned.
Re: Hood Scoop [Re: Kaminsky] #2915924
04/27/21 10:40 PM
04/27/21 10:40 PM
WA
JD Dart Offline
JD Dart  Offline
WA
I re-did my hood scoop the old one had only 1-1/2" over the rear barrels the new one has 4-3/4" picked up 2 mph and when it comes off the stop it pulls super strong and never quits pulling.
Doing a new hood scoop is not an easy task if you do a custom but sometimes it's they only way to make it right.
Picture of new and the old setup.
best so far 8.53 @ 158.59 MPH 60'1.240
Re: Hood Scoop [Re: gsmopar] #2916429
04/29/21 08:32 AM
04/29/21 08:32 AM
an8sec70cuda Offline
iagree up
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Hood Scoop [Re: an8sec70cuda] #2916452
04/29/21 09:14 AM
04/29/21 09:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
When I set up my hood I was trying for more air and a straight run into the intake.. love the scoop
I have(forgot the company)
wave
Re: Hood Scoop [Re: Kaminsky] #2916639
04/29/21 06:08 PM
04/29/21 06:08 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Most (actually all) Bigger HP cars I do here the scoop gets mounted to the carbs and we cut the hood around the scoop. May save you some $$ and have a scoop that is more beneficial.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
