Light weight front brake kit for disc spindles #2915904
04/27/21 09:41 PM
04/27/21 09:41 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Need to replace front rotors on 1972 plymouth satellite and thought about trying to knock some weight off. Can't find any race kits for disc spindles any one know of a kit?
Re: Light weight front brake kit for disc spindles [Re: Dart451] #2915964
04/28/21 01:18 AM
04/28/21 01:18 AM
Northern Bavaria / Germany
MichaelF Offline
MichaelF  Offline
There is this wilwood kit:
https://www.wilwood.com/BrakeKits/B...=Satellite&option=Disc+Brake+Spindle
DonĀ“t know if you are searching for some more Drag-oriented stuff.
Michael
Re: Light weight front brake kit for disc spindles [Re: MichaelF] #2915981
04/28/21 06:41 AM
04/28/21 06:41 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Dr Diff makes a bearing sleeve that allows use of the later 73-up rotor (1.375" inner bearing ID vs 1.25") so you can expand your options. I like the 11.75" rotor/wilwood dynalite kit originally designed by AR Engineering and now sold by Dr Diff.
Re: Light weight front brake kit for disc spindles [Re: Jeremiah] #2916007
04/28/21 08:42 AM
04/28/21 08:42 AM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Was initially looking for something like this
Brake
Will see what the Dr Diff adapter opens up for options.
Might be better off to just replace what I have and look to do a rack conversion next winter
Re: Light weight front brake kit for disc spindles [Re: Dart451] #2916023
04/28/21 09:27 AM
04/28/21 09:27 AM
BDW Online content
BDW  Online Content
Brake
That set-up says its only good for cars weighing under 2800lbs.......... And that's for 4-wheel disc
Only 2400lbs if you have drums in the back
Re: Light weight front brake kit for disc spindles [Re: BDW] #2916092
04/28/21 12:30 PM
04/28/21 12:30 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
I do have disk in back and car would be little over weight but was hoping there something similar with little more weight rating
Re: Light weight front brake kit for disc spindles [Re: Dart451] #2916122
04/28/21 01:39 PM
04/28/21 01:39 PM
Alberta,Canada
605ply Offline
605ply  Offline
Alberta,Canada
just get a vented rotor kit....aerospace is good too and had a 25% sale that went on for a few months over the winter
Re: Light weight front brake kit for disc spindles [Re: Dart451] #2916178
04/28/21 03:56 PM
04/28/21 03:56 PM
Call or contact Strange Engr. to see if they have a good kit for your deal twocents scope
