Page 3 of 3 1 2 3
Re: Nitrogen filled tires increase mileage ? [Re: DPelletier] #29142
08/02/06 03:38 PM
08/02/06 03:38 PM
NC
DCM71cuda Offline
DCM71cuda  Offline
NC
Nascar guys would use N2 in the tires because it would have the same effect all the time. In other words, if you fill the tire to 30 psi with air [cold], and it heats up to 180 during a run, what is the pressure at that point with the elevated temperature? Depending upon the amount of N2, O2, CO2, etc, that could vary.
If you are using N2, it should be the same amount of change in pressure every time for a given temperature rise.
Re: Nitrogen filled tires increase mileage ? [Re: DCM71cuda] #29143
08/02/06 04:08 PM
08/02/06 04:08 PM
N. of 8mile, S. of heaven
Spike Offline
Go Blue!!
Spike  Offline
Go Blue!!
Local tire store is promoting the heck out of nitro filled tires.
Belle tire Click on the Nitro Nize and see how much $$$ you'll save!!! Give them credit for making it sound like the next best thing since O2 itself.
Re: Nitrogen filled tires increase mileage ? [Re: Spike] #29144
08/02/06 04:37 PM
08/02/06 04:37 PM
ROLL TIDE ROLL
Dick H. Offline
Tin Man
Dick H.  Offline
Tin Man
ROLL TIDE ROLL
When I was in HS, we had a half-baked punter on our football team who insisted on filling the punting ball with helium, "for better hang time and distance." He was a real piece of work, and swore it made a difference, but nobody else could tell.
Go figure.
Re: Nitrogen filled tires increase mileage ? [Re: Dick H.] #29145
08/02/06 05:07 PM
08/02/06 05:07 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Go figure.
Yep, the same kind of people buy fuel magnets and intake "tornados"!
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Nitrogen filled tires increase mileage ? [Re: DPelletier] #29146
08/02/06 05:29 PM
08/02/06 05:29 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
I think the reason Nascar uses it is for pure convenience, as someone metioned above, it's a risky biz compressing "air" to 2000 lbs that is in a N2 bottle, it's done, but not cheap, after the air is seperated into N2 and 02 in a cold box, then the N2 is fairly easy to compress that high.
Re: Nitrogen filled tires increase mileage ? [Re: wyoming] #29147
08/02/06 05:51 PM
08/02/06 05:51 PM
NC
DCM71cuda Offline
DCM71cuda  Offline
NC
Quoted from interview with Cup Crew Chief:
When the tire heats up, the moisture inside it will vaporize and expand, increasing the tire pressure. By using nitrogen instead of air, we have more control over how much the pressure will build when the tires heat up.
We also use nitrogen to power the air guns for pit stops, for the same reason. Those guns are expensive tools, and the moisture in compressed air would damage them.
Post deleted by Defbob [Re: 68HemiB] #29148
08/02/06 07:45 PM
08/02/06 07:45 PM
Anonymous OP
Anonymous OP
Re: Nitrogen filled tires increase mileage ? [Re: MikeP] #29149
08/02/06 08:17 PM
08/02/06 08:17 PM
Anonymous OP
Anonymous OP
Nascar use's it.....They tweak in 1/2lb adjustments(critcal long run adjustment) so the more stable the inflation gas the better......
I worked on on a Busch North team (now East Series) for 2 yrs in Nascar. Couple of races I was responsible for tires.
Nitrogen is used because it's expansion is much more controllable than using regular air. With compressed air from a tank, you have moisture that gets placed in the tires. When the tire heats up, the moisture expands at a diffrent rate than the air, so it made adjusting tough. This is also why tires are installed dry (no soapy water), they found out that some tires were exploding due to the water inside the tire turning to steam and blowing the tire apart.
As for using nitrogen in the air guns, it's not convenience, it's necessity. Since nitrogen is denser than air, you get much more volume of gas going thru the gun when removing lug nuts. More gas means faster rotational rate. Faster rotational rate means nuts get loosened faster.
Re: Nitrogen filled tires increase mileage ? #29150
08/02/06 10:27 PM
08/02/06 10:27 PM
SC
V194 Offline
V194  Offline
SC
According to the ideal gas law (pV = nRT) there is no difference in pressure rise of the different gases given a constant mass and volume.
oh, oh, I know this one!
6.022 x 10^23
What do I win?
(It's been about 30 years since my college chem class, and you have no idea how little I get to use stuff like this.)
Hey, that's Avogadro's Number! One of the few things I still remember from Chem class.
Yep Just remember your ABC's
Avogadro's Number Boyle's Law
Charles' Law
Post deleted by moparts #29151
08/02/06 10:44 PM
08/02/06 10:44 PM
Anonymous OP
Anonymous OP
Re: Nitrogen filled tires increase mileage ? #29152
08/02/06 11:04 PM
08/02/06 11:04 PM
Illinois
SGTFURY62 Offline
SGTFURY62  Offline
Illinois
Ahhh nitrogen...I guess that would solve me having to twist my air gun back and forth to get my lug nuts off while I squeeze the trigger(you all know you've done it). Or I could just wait for the pressure to build up.
Re: Nitrogen filled tires increase mileage ? #29153
08/02/06 11:24 PM
08/02/06 11:24 PM
Slantytown
DUFFMAN Offline
Ask And Ye Shall Receive
DUFFMAN  Offline
Slantytown
Wow, I don't even know where to start. You need to read about Boyle's Law and learn a little about fluid dynamics.
No longer taking $h!t from anyone!
Re: Nitrogen filled tires increase mileage ? [Re: DPelletier] #29154
08/02/06 11:43 PM
08/02/06 11:43 PM
N
Nuclear1 Offline
Nuclear1  Offline
N
After reading this thread out, I have to give it to you guys, you have remembered a bit of chemistry that most people try to forget. As a chemist (Ph.D. graduate student finishing up my last year), I have had to teach basic chemistry concepts as a teaching assistant and it never seems to amaze me the lenghts people will go to avoid learning them......
As for the topic itself, I could not believe the first time I saw a company in town charging $20 for this service. I understand the need for it in high temperature/heavy load circumstances, but it is a complete waste of money for the average consumer in my opinion......
BTW, I will now sound like like my grandfather:
Remember when regular air was free at most gas stations?.......
Re: Nitrogen filled tires increase mileage ? [Re: Nuclear1] #29155
08/02/06 11:58 PM
08/02/06 11:58 PM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
Navy and maybe the rest of the military went to nitrogen because of hot brakes and fires, nice thing it also was stable for heat as it rolled, I'd guess if you ut it in car tires it would hold is press reading so if you run a couple of pounds high for milage it would be better but just because it was in a tire I doubt it do much at all.
Re: Nitrogen filled tires increase mileage ? [Re: 69DartGT] #29156
08/03/06 09:39 AM
08/03/06 09:39 AM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
Our schools teach kids weird stuff....the world is full of kids/people that pay $1 for a 12 ounce bottle of water.???? yet they [Edited by Moparts - Keep it clean] about the gasoline prices??? this new nitrogen idea will make lot $$ for a few clever people
Re: Nitrogen filled tires increase mileage ? [Re: DUFFMAN] #29157
08/03/06 09:29 PM
08/03/06 09:29 PM
Anonymous OP
Anonymous OP
Little far off? Me just knows what I was told.. I leave all the geeky E=MC2 to the pocket protector types..
Re: Nitrogen filled tires increase mileage ? [Re: shanker] #29158
08/04/06 11:15 PM
08/04/06 11:15 PM
L.I. N.Y. Hemi Street
HemiGreg Offline
HemiGreg  Offline
I wonder if Helium would yield abother 1mpg over that?
Here is the deal, Nitrogen makes up 85% of our atmosphere, the air compressor that is used to fill tires up, is compressing 85% nitrogen as it is, that news channel is full of it. There was a thread on this a while back
Wrong---- Atmospheric air is at best 80% N2, 20% oxygen and miniscule amounts of everything else
the only place you will see 85% n2 is on top of 6-8000 ft elevation and even then theres more He and H cause the molecules are so small and light gravity dont pull em down- see your perodic table of elements, I got one hangs in front of me all night here at work.
N2 and argone are best for intermoleculr space and resisting heat expansion thats why its put in double plane windows to avoid heat conduction.
but as a scientist i cant go along with it inproving milege beyond .10% max as the expansion coefficient will not mathmatically work out unless the tire has a volumetric capacity of over 10 cubic feet.
now on the football nut, I filled a basket ball with 99.9999%pute Hydrogen which has morelift than Helium dropped both from my roof (25feet) off the same tilted board and the H2 ball bounced 10-12" higher after 10 trials, it does work, but most guys cant get 5-9s Hydroged.
isnt chemestry and physics great
Re: Nitrogen filled tires increase mileage ? #29159
08/05/06 02:46 AM
08/05/06 02:46 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Local news article claimed 1-1.5 mpg improvement. Anyone here tried it ?
Total BS.
When you just fill a tire with nitrogen it's not 100 % nitrogen in it. There is still regualer air in there. Anyways the expansion of diameter of the tire while hot is mostly a fuction of the humidity of gas trapped in a tire.
I crew on a very competitive local NASCAR crew. We watch the diameter growth of tire with respect to tempurature. Just putting in nitrogen doesn't cut it. We need to PURGE the tires of all their gasses about 3-5 TIMES to get the humity down to 3-8%. We have a special tire air humidity guage to check this.
Now if the tire monkey that mounts your tires uses and bunch of soap and water to mount your tires, you have a bunch of humidity trapped in them.
Another advantage of filling a tire with Nitrogen is that the itsmolecules are thicker and bigger than air..
So if the tire has a slow leak it takes considerably longer for the tire to deflate.......
I don't buy that. Gas molecules thick or not can get by any leak.
If regular air expands more with heat than straight N2 then you would think that you get better mileage with regular air as the pressure builds and rolling resistance goes down.
That's a good point. I remember when honda offered the CRX HF (high efficiancy) model than had narrower tires with high recommended inflation pressures.
From what I understand it's out of convienence. They have pressurized nitrogen readily available and don't need to have a compressor. I'm not sure what they already use the nitrogen for, maybe someone else does?
Yes it is convenient. It's about the cheapest thing out of a tank and will run a air tools. And you can turn the pressure up more than a common compressor can pump out for those tricked out ported NASCAR air guns.
Re: Nitrogen filled tires increase mileage ? [Re: autoxcuda] #29160
08/05/06 05:07 AM
08/05/06 05:07 AM
NW
hergfest Offline
hergfest  Offline
NW
Costco does N2 in their tires at no additional cost. That is why my Charger has green valvwe stem caps...lol
Page 3 of 3 1 2 3
