70 GTX- front alignment specs #2914491
04/24/21 08:27 PM
04/24/21 08:27 PM
NH
N
NHCharger Offline OP
N
NH
Buddy of mine just installed power steering in his 70 GTX, 440. He's waiting for Roger from the GTX registry to get back to him on factory alignment specs.
Told him I'm sure someone here has a FSM that could provide this info.
I have a FSM for my 69 Charger but not sure it's the same for 70.
TIA
My Dad always told me, when setting goals " avoid disappointment, aim low".
Re: 70 GTX- front alignment specs [Re: NHCharger] #2914597
04/25/21 06:38 AM
04/25/21 06:38 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Stock specs would be the same. But, if he's running radial tires, he ought to have more caster dialed in.
I've been pleased with 2.5 degrees caster, 0 camber and 1/16th toe in.
Angry white pureblood male
Re: 70 GTX- front alignment specs [Re: ruderunner] #2914618
04/25/21 08:28 AM
04/25/21 08:28 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
if he is using radial tires pretty much all mopars alignment specs for daily driving should be
1/2-1* neg camber.
as much positive caster as you can get with the stock parts.
1/16" neg toe.
perception is 90% of reality
Re: 70 GTX- front alignment specs [Re: NHCharger] #2914686
04/25/21 10:48 AM
04/25/21 10:48 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
The specs provided here are better starting points than the original FSM specs. I say starting points because that is what they are..starting points. Use them and then test drive the car for a few minutes. Then put it back on the rack and have the adjustments made so that the car drives to your liking. Or just goes down the road straight.
Every one of my cars have needed to go back on the rack after a test drive even though all the specs were 'in the green'. Often one or more specs are 'in the red' in order to get the car to go down the road straight. And I usually sit in the car or have my approximate weight in the car while adjusting the front end. Then there's the question as to whether to add weight to the passenger seat. All that will significantly change the settings.
And our cars will not usually come into spec without offset upper control arm bushings or modifying the rear arm of the uppers.
twocents
Master, again and still
Re: 70 GTX- front alignment specs [Re: ruderunner] #2914753
04/25/21 01:19 PM
04/25/21 01:19 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I've been doing alignments for a long time and this is where I would try to get it. I would split the caster a bit(little less pos on the left) to compensate for road crown
Re: 70 GTX- front alignment specs [Re: Dcuda69] #2914768
04/25/21 01:51 PM
04/25/21 01:51 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Yes a split is good areas with lots of road crown.
Re: 70 GTX- front alignment specs [Re: ruderunner] #2914825
04/25/21 04:03 PM
04/25/21 04:03 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Last one i had done.
I think i had them get it as much NEGATIVE caster as they could. Then get camber as close to 0 or 1/2 negative as possible
Re: 70 GTX- front alignment specs [Re: gtx6970] #2914885
04/25/21 07:31 PM
04/25/21 07:31 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I think you made a mistake in your post. Negative caster is the opposite of what you want.
Re: 70 GTX- front alignment specs [Re: Kern Dog] #2914900
04/25/21 08:08 PM
04/25/21 08:08 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Could be, been a while since Ive had one done
Re: 70 GTX- front alignment specs [Re: gtx6970] #2915011
04/26/21 02:56 AM
04/26/21 02:56 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Negative caster tilts the knuckle forward and greatly reduces stability. The steering wanders and the wheel does NOT return to center after a turn. The faster you go, the more twitchy the steering feels...
Re: 70 GTX- front alignment specs [Re: Kern Dog] #2915021
04/26/21 07:23 AM
04/26/21 07:23 AM
Mr T2U Offline
Mr T2U  Offline
with NEGATIVE caster
a great comparison is the front wheels on a shopping cart. they wander all over the place and never track straight.
yes they have EXTREME negative caster compared to a car but it gets much easier to understand what it does.
