ront Disc Conversion Kits for a 14" wheels? 64 Dodge 880 #2913822
04/23/21 11:14 AM
04/23/21 11:14 AM
Baton Rouge
64Custom880 Offline OP
Baton Rouge
Hello. My 1964 Dodge custom 880 has 14" inch wheels and I don't want to upgrade to 15" wheels. Can anyone recommend front disc conversion kits that work with 14" wheels...most 1964 mopar kits requires at a minimum 15" wheels.
I see that PST makes a kit. What are your thoughts? Link below
https://p-s-t.com/i-23162314-front-spindle-mount-disc-brake-conversion-kit.html
Re: ront Disc Conversion Kits for a 14" wheels? 64 Dodge 880 [Re: 64Custom880] #2913865
04/23/21 12:12 PM
04/23/21 12:12 PM
moparx Offline
moparx  Offline
use the FMJ spindles [aspen/volare] and small discs used with 14" wheels.
not sure what the availability is in your area, or the cost.
if you use those, the tie rod sleeve will have to be shortened, or a new one made to get the toe in spec.
it goes without saying, you will need wheels compatible with discs.
beer
Re: ront Disc Conversion Kits for a 14" wheels? 64 Dodge 880 [Re: 64Custom880] #2913967
04/23/21 03:41 PM
04/23/21 03:41 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Doc Diff has a kit that will clear 14" disc-spec wheels. Scarebird will clear the OEM 14" wheels.
https://scarebird.com/index.php?route=product/product&path=64&product_id=158
Re: ront Disc Conversion Kits for a 14" wheels? 64 Dodge 880 [Re: John_Kunkel] #2913974
04/23/21 04:13 PM
04/23/21 04:13 PM
Ontario, Canada
GVH Offline
GVH  Offline
Ontario, Canada
Use 73 up A body spindles and parts as pre the Mopar action article
from years ago uses all mopar or jobber parts .
Re: ront Disc Conversion Kits for a 14" wheels? 64 Dodge 880 [Re: GVH] #2913985
04/23/21 04:37 PM
04/23/21 04:37 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Do that and you will have a spindle about 3/8" shorter than the 880 came with.
The FMJ spindle is the same height.
Same front setup as my 64 300 had, I used the brakes off a 79 Cordoba. Spindle height is the same but the tie rods need shortening to fix the toe. I can't remember if I reused the 64's steering arm, or used the 79's. I want to say the 79's.
Don't forget that on both the FMJ and the 880 the LBJ is NOT part of the steering arm like it is on an A body.
