Re: Nitrogen filled tires increase mileage ?
[Re: RoadRunner]
#29123
08/02/06 09:45 AM
08/02/06 09:45 AM
Posts: 17,092 Brookline NH
Tesla_HV
Brookline NH
N2 and air are, for all intensive purposes, the same. That is, any heat expansion air has, the N2 will have too. But what N2 doesn't have is moisture and CO2 which do vary vapor pressure greatly with temperature fluctuations a tire will be exposed to. Also, as stated, there is no O2 to contribute to corrosion (or moisture) and the lack of O2 will prevent the rubber from braking down on the inside. For the money these guys are charging for N2 though, man, thats a racquet. I work in the air seperation industry and know what it takes to generate N2.
I question the premise that pure nitrogen expands at a different rate than air. According to the ideal gas law (pV = nRT) there is no difference in pressure rise of the different gases given a constant mass and volume.
If you are in the air separation industry, you would be interested in the consumption at the place I used to work at. They used liquid nitrogen to cool copper conductors for high magnetic field magnets. In a year, the experiment uses ~2 million gallons of LN2 at a cost of over $500K.
[Re: DUFFMAN]
#29125
08/02/06 09:58 AM
08/02/06 09:58 AM
I think this thread was spoiled before we got here!
[Re: BobR]
#29128
08/02/06 10:35 AM
08/02/06 10:35 AM
Posts: 2,368 Wheatfield, NY
Cuda340
Wheatfield, NY
As ealier stated the benefit of nitrogen in the tires is the bigger molecules. They tend to stay inside the tire and tires stay the correct pressure longer. Tire does not have to have a hole in it for air to escape. Air escapes from sound tires over time. Nitrogen escapes more slowly. This is what the higher fuel mileage is attributable to. -Bob
How can this be true if the atomic weight of nitrogen is 14.01 and the atomic weight of oxygen is 16.00?
[Re: Cuda340]
#29129
08/02/06 10:45 AM
08/02/06 10:45 AM
Isn't this a great thread!!!
[Re: BobR]
#29130
08/02/06 10:51 AM
08/02/06 10:51 AM
Posts: 11,269 Slantytown
DUFFMAN
Ask And Ye Shall Receive
Slantytown
Here's something I found on an engineering website about the since behind it, or lack ther of. I found it to be a very well thought out explaination. Quote:
The question about nitrogen in tires has come up in other lists on the web as well. Let me clarrify a few points.
1. Air is 78% nitrogen, N2, and 21% oxygen, O2. So even if you put air in the tire, it's already 78% nitrogen. Many of the so called nitrogen generators don't produce much more than 90% nitrogen.
2. At relatively low pressures (ie tire pressures) N2, O2 and water vapor will all behave as ideal gases, and follow PV=nRT. Pressure will increase or decrease to the same extent as the temperature increases or decreases regardless of which gas is in the tire. (Even at 300 psi, which is about 20 atm, there is little deviation from ideality.) Therefore the comments about N2 not changing in pressure as the temperature changes are without merit.
3. The rate of effusion (or diffusion) of a gas through a porous membrane depends on the molar mass and to some degree on the molecular diameter. N2 and O2 are almost the same size and N2 is lighter than O2 (28 g/mol vs 32 g/mol) so if either gas were to effuse out of the tire, nitrogen would do it more quickly. Luckily, tires are designed not to be porous membranes.
4. N2 and O2 both have essentially the same specific heat capacity, about 1.0 J/gK, and thermal conductivity, about 0.00026 W/cmK. Water vapor has a specific heat capacity of about 2 J/gK. But remember, water vapor will constitute less than 1% of the air in the tire. So the idea that N2 has different heat handling properties is also without merit.
5. The ozone, O3, in the atmosphere, which is a ground level pollutant, will do a great deal more damage to your tires than the O2 inside the tire. For instance, don't leave a condom out in the air in Los Angeles for a few days. It will develop lots of tiny holes and weaken. spdracer22 says that dry air is preferably to air with a lot of water vapor. As a tire heats up, the very small amount of H2O present will be in the vapor state which may contribute to the overall pressure very slightly.
Several have suggested that N2 in a high pressure tank is more portable and requires no electricity. That would make sense, particularly for aircraft tires.
I find no reason to believe that N2 is going to produce a "better ride" or "better handling".
The bottom line is that for general passenger car tires or truck tires there is nothing to be gained (other than portability) by using nitrogen rather than air. The biggest gain will be $$$ by the companies that sell nitrogen handling equipment and the tire merchants that appeal to ignorant customers. And who is the biggest loser? Yep, the consumer.
No longer taking $h!t from anyone!
[Re: Tesla_HV]
#29131
08/02/06 11:36 AM
08/02/06 11:36 AM
Posts: 5,139 East Aurora (Buffalo) NY
RoadRunner
Thats what I was trying to say, there really is no difference between air and N2 other than trace amounts of moisture and CO2 in air that is compressed. Heck, if you fill up the tires after a dryer then the moisture amount is pretty small too. In general, I think its a gimmick.
So who has the $500k per year account for your LN2? Thats a chunck of change for product. Our major expansions right now are in the oil indistry where they are injecting liquid N2 and LCO2 into the ground for enhanced oil recovery.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: RoadRunner]
#29132
08/02/06 11:45 AM
08/02/06 11:45 AM
Tesla_HV
Brookline NH
It is a physics experiment at the MIT Plasma Science and Fusion Center. During peak usage, it consumes 14,000 gallons of LN2 per day.
[Re: 68HemiB]
#29134
08/02/06 01:16 PM
08/02/06 01:16 PM
Tesla_HV
Brookline NH
oh, oh, I know this one!
6.022 x 10^23
What do I win?
(It's been about 30 years since my college chem class, and you have no idea how little I get to use stuff like this.)
But I'm sure the question everyone wants answered is "what about acetone in the tires?" (I bet you thought I was gonna say ear wax...)
Back to the original subject, you have to admit it's a pretty clever idea to separate consumers from a little extra money on a tire sale: $5 per tire to fill it with nitrogen.
You win a cold 40oz. bottle of Steel Reserve 211!
I've been wondering about why NASCAR uses nitrogen if there is little difference in pressure rise with temperature. I wonder if it has to do with the presence of oxygen in the air under pressure and the potential for explosions in an accident? Anyone know?
[Re: BobR]
#29137
08/02/06 01:31 PM
08/02/06 01:31 PM
Posts: 3,925 ROLL TIDE ROLL
Dick H.
Tin Man
Tin Man
ROLL TIDE ROLL
"Back to the original subject, you have to admit it's a pretty clever idea to separate consumers from a little extra money on a tire sale: $5 per tire to fill it with nitrogen."
I guess they are just no smarter than the average consumer. -Bob
That still doesn't explain why most turbine aircraft manufacturers and the FAA pretty much mandate "dry nitrogen only" in aircraft tires. They do it primarily because it gives the least pressure variation with temperature change and secondarily because moisture causes corrosion and can freeze at altitude. It has nothing to do with portability. Almost every small shop has an air compressor, while not all of them bother with the expense of a nitrogen tank setup.
[Re: 5537SG]
#29139
08/02/06 02:31 PM
08/02/06 02:31 PM
Posts: 9,316 SoCal
68HemiB
SoCal
Others weigh in: 1. Oxygen=bad source: Goodyear Aircraft Tire Website Goodyear web page "Nitrogen will not sustain combustion and will reduce degradation of the liner material, casing plies and wheel due to oxidation." 2. Water vapor messes with PV=nRT source: Car Talk (Tom & Ray - my favorite scientists) Car Talk article "The reason nitrogen pressure stays more constant than air pressure is because air contains water vapor, and so it expands less predictably than nitrogen. There's a different percentage of water vapor in the air on any given day (a k a the humidity), so you never know exactly how much tire expansion you'll get from the water vapor."
Down to just a blue car now.
[Re: 68HemiB]
#29141
08/02/06 03:15 PM
08/02/06 03:15 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Just to be clear; - Nitrogen has some benefits with regards to temperature fluctuations as evidenced by thier use for aircraft, but anyone claiming a mpg improvement by running nitrogen over compressed air has rocks in thier head. Run the correct tire pressure and call it a day. Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
