H wheel ??? #2912768
04/21/21 08:55 AM
04/21/21 08:55 AM
Lansing, MI
70gtx440dana Offline OP
Lansing, MI
Can anyone shed some light on this 2944169 H wheel. Appears to be dated 2 22 71 (M51) next to valve stem. Would this be a service part? Or, did Mopar use these in production after 1969? What is the estimated value of a single wheel dated 71 versus the more desirable 68-69 dates.? H is visible on front side. Just filled in with a couple coats of paint.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: H wheel ??? [Re: 70gtx440dana] #2912794
04/21/21 10:12 AM
04/21/21 10:12 AM
VA
dragon slayer Offline
VA
68 Hemi 15" are a different wheel with different looking front side. They are JK wheels. In 69 the wheels went to a JJ wheel. These where on P&D cars also. The 69 parts book shows the same part number but separate line for RW versus PD and the PD was called out for Heavy Duty, not the RW.
In 70/71 a lot of models used that part number.
Re: H wheel ??? [Re: 70gtx440dana] #2913143
04/21/21 08:23 PM
04/21/21 08:23 PM
Elizabethtown, KY
6T9Hemi Offline
6T9Hemi  Offline
Elizabethtown, KY
That is a 71 "H" wheel. It is the 870 rim same as the 69. In 1970 and 71 they put the part number by the valve stem hole, the 69 wheels did not have the part number on them. They are the same wheel spec wise, but do not have the value of the 69 wheels that came on Hemi B bodies and the A12 cars.
1969 340 4 Speed Swinger R4,
black vinyl, white butt stripe, 3:91
