Re: champion plug J11Y
[Re: moparx]
#2912285
04/20/21 12:56 PM
04/20/21 12:56 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
wasn't the Y series a projected nose design ? Champion did use the Y suffix to identify the projected tip spark plugs ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) OP, these are a non resistor plug also and may not be legal in your state ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) OP, if your motor has stock heads and pistons I would look at using the old Champion part # RJ12YC ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) if you have aluminum heads you will need a 3/4 reach plug which will have a N or RN prefix or RC prefix. The RN uses a 13/16 inch body socket size and the RC uses a 5/8 inch body, both use gaskets and are resistor plugs ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
[Re: lewtot184]
#2912375
04/20/21 03:33 PM
04/20/21 03:33 PM
Posts: 4,760 Moved to N.E. Tennessee
GomangoCuda
J11 is a lawn mower plug. Probably also works in a small block chevy ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) Personally, I prefer NGK XR5 for a stock compression iron head BBM.
[Re: hp383]
#2912470
04/20/21 05:57 PM
04/20/21 05:57 PM
Cab_Burge
The federal government outlawed non resistor spark plugs along with solid core spark plug wires to eliminate EMF, electromagnetic interference caused by them. Back in the day, around 1962 I think, before them being outlawed you see and hear that electrical interference on the T.V. and hear it on AM radios ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) In todays digital world they probably would be not causing the same issues ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif)
[Re: Cab_Burge]
#2913120
04/21/21 07:44 PM
04/21/21 07:44 PM
Posts: 959 Cincinnati,Ohio
jcastle1
Cincinnati,Ohio
I have hundreds of original Made In USA 8 packs of the Mopar Champion J12Y spark plugs if anyone is interested. The original cartons have the sticker that garages used to stick on the B pillar for when the service was done. The packaging states Mopar/Champion The original part number on the box is 4106121. Made by Champion Spark Plug Co. Toledo, Ohio Sorry this is not in the "for sale" section. I really never thought about selling any until someone mention them. Pics upon request
