Big Block 400? #291233
04/17/09 05:57 PM
04/17/09 05:57 PM
Anonymous OP
Anonymous OP
Have some number off the block want to make sure what this is. On the Block the number 3830830-1-400
and on the bottom of that there's another number
looks like a build date 12.3.74. Thanks for the help.
Re: Big Block 400? #291234
04/17/09 06:21 PM
04/17/09 06:21 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
I don't know casting numbers but judging by that vacuum cannister, lack of casting pad beside the distributor and 2 barrel intake. I'd say it's a 400.
You are going to need a 400 harmonic balancer.
Re: Big Block 400? [Re: Magnum] #291235
04/17/09 07:16 PM
04/17/09 07:16 PM
Anonymous OP
Anonymous OP
I gotta 440 crank thinkin about stroking it..My buddy who gave me the motor says it has a spun bearing haven't opened it up yet.
Re: Big Block 400? #291236
04/17/09 07:35 PM
04/17/09 07:35 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Thats what I'd do!!
Re: Big Block 400? [Re: StealthWedge67] #291237
04/17/09 09:11 PM
04/17/09 09:11 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
You sure about that casting #?
Re: Big Block 400? [Re: StealthWedge67] #291238
04/17/09 09:38 PM
04/17/09 09:38 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
Thats what I'd do!!
I agree with stroking it, but if you go to all
the work of it, you might as well go with the
512 kit from the source.
Snap your neck, mega G-force launch, is all I want!
Re: Big Block 400? #291239
04/17/09 10:02 PM
04/17/09 10:02 PM
salem, oregon. usa
E
elmor Offline
elmor  Offline
E
salem, oregon. usa
From the casting date I'd say it's a 75 400.
Re: Big Block 400? [Re: elmor] #291240
04/18/09 12:11 AM
04/18/09 12:11 AM
California
P
polkat Offline
mopar addict
polkat  Offline
mopar addict
P
California
Should be a pad that is an extension of the deck surface in front of the passengers head (the books always say it's next to the distributor-but it's higher up in front of the blocks head surface). It is usually covered with crud you have to scrape off to see the stampings. If the number 400 is stamped on it, it's a 400. Mine has this pad, and I'm sure all 400's have it...., unless the deck surface has been milled down enough to erase it!
Re: Big Block 400? [Re: polkat] #291241
04/18/09 12:04 PM
04/18/09 12:04 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
The last "400" of the casting numbers is the CID. A 440 would say 440, and so on.
