MSD starter saver
#2911732
04/18/21 08:22 PM
04/18/21 08:22 PM
Posts: 3,253 Md.
carnut68
Md.
i'm considering locking my Pro billet dist. Does the starter saver work as advertised or is it an unreliable gimmick ? I'm still running an 6AL analog ignition box.
America First!
Re: MSD starter saver
[Re: carnut68]
#2911819
04/18/21 11:33 PM
04/18/21 11:33 PM
Posts: 610 Boise
Moparteacher
Boise
I have a MSD Billet dizzy locked-out with a 20 tear-old 6AL. I tried a MSD start retard box. It worked, but I noticed the timing retarding as rpm's increased. I read somewhere that it's a common issue. I removed the start retard and the issue went away. You may want to consider a fast crank with a separate ignition switch. Get the engine cranking and then turn on the ignition. Powermaster makes a starter that's designed to crank at a faster speed. Your results may vary.
I also needed an adjustable rotor to clock it at the tower. Go figure. I may sell the bunch and go crank/cam trigger with CNP.
[Re: Moparteacher]
#2911836
04/19/21 06:13 AM
04/19/21 06:13 AM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
You are probably fine without the starter saver if you have a good starter and battery. I ran 35* locked out for a long time with no saver or anything. I did eventually train myself to crank it then turn the ignition on to ease things but it wasn't needed.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2911843
04/19/21 07:26 AM
04/19/21 07:26 AM
Posts: 3,253 Md.
carnut68
Md.
You are probably fine without the starter saver if you have a good starter and battery. I ran 35* locked out for a long time with no saver or anything. I did eventually train myself to crank it then turn the ignition on to ease things but it wasn't needed. I'm still running an old factory starter, new battery. Next time the engine comes out it'll have a mini starter. I was just trying to avoid the ignition cut off switch.
America First!
[Re: carnut68]
#2911861
04/19/21 08:28 AM
04/19/21 08:28 AM
Posts: 4,457 Washington
madscientist
Washington
i'm considering locking my Pro billet dist. Does the starter saver work as advertised or is it an unreliable gimmick ? I'm still running an 6AL analog ignition box. All ignition boxes retard with RPM. I wouldn’t lock it out unless you have some other way to compensate for that retard. I know it’s done on a regular basis, but it’s not really a good thing.
[Re: madscientist]
#2911985
04/19/21 04:02 PM
04/19/21 04:02 PM
Posts: 3,253 Md.
carnut68
Md.
i'm considering locking my Pro billet dist. Does the starter saver work as advertised or is it an unreliable gimmick ? I'm still running an 6AL analog ignition box. All ignition boxes retard with RPM. I wouldn’t lock it out unless you have some other way to compensate for that retard. I know it’s done on a regular basis, but it’s not really a good thing. Here's my issue. My car wants more idle timing. Currently it's @ 24 with a 10 degree bushing total is 34. All in about 2000. Idles around 12-1300 but it's not happy. Cam is 271 @ 50. With the MSD dist. if you bump the idle timing up to say 28 then the total goes to 38. Other than modifying the advance slots for less total, locking is the only option. Or buy something programmable.
America First!
[Re: lancer493]
#2912046
04/19/21 06:32 PM
04/19/21 06:32 PM
Posts: 3,253 Md.
carnut68
Md.
You should be able to change the rate of advance with lighter rate advance springs or possibly using only one spring to bring that advance in dramatically quicker.That would allow you to keep your 24* base and have your 1200 to 1300rpm timing already in a higher advance position, yet keeping your total at your desired 34*. If it already starts well at 24* degrees, you just need a rate change. Experiment with stretching a spring a little at a time possibly in conjunction with eliminating one.Chevy racers used to do that trick years ago on their stock distributors and they appear to be quite similar to the MSD billet dist. Bill I thought about trying 1 spring. I have a bunch of springs from some of the Chev's I had. No problems starting at 24 or even 26. I could still put a switch on the box as a backup.
America First!
