Re: Testing neutral saftey switches.
[Re: jughed]
#2911685
04/18/21 05:33 PM
04/18/21 05:33 PM
Posts: 25,871 Rio Linda, CA
John_Kunkel
Rio Linda, CA
To test the single, check for continuity between the outer post and the inner metal contact.
For the 3-prong, check for continuity between the center outer prong and the inner metal contact; then check for continuity between the two outer prongs. When the inner spring-loaded metal contact is depressed you should lose continuity between the two outer prongs.
[Re: John_Kunkel]
#2911798
04/18/21 10:30 PM
04/18/21 10:30 PM
Posts: 1,229 In The Hills
jughed
In The Hills
For the 3-prong, check for continuity between the center outer prong and the inner metal contact; then check for continuity between the two outer prongs. When the inner spring-loaded metal contact is depressed you should lose continuity between the two outer prongs. Thank you!!! The single prong reads continuity whether or not the button is pushed in...is that normal? I would think that a switch is a switch.
[Re: jughed]
#2911937
04/19/21 01:28 PM
04/19/21 01:28 PM
John_Kunkel
Rio Linda, CA
Yes, both switches will read continuity on the NS pin whether depressed or not.
[Re: jughed]
#2912308
04/20/21 01:37 PM
04/20/21 01:37 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
For the 3-prong, check for continuity between the center outer prong and the inner metal contact; then check for continuity between the two outer prongs. When the inner spring-loaded metal contact is depressed you should lose continuity between the two outer prongs. Thank you!!! The single prong reads continuity whether or not the button is pushed in...is that normal? I would think that a switch is a switch. If your asking about the center conductor, wire, shaft in both types of neutral switches it will have continuity if it is not broken
