Page 41 of 48 1 2 39 40 41 42 43 47 48
Re: Modern Bullitt build [Re: NITROUSN] #2904875
04/01/21 11:03 AM
04/01/21 11:03 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Originally Posted by NITROUSN
Very nice. Any pics on the antenna motor mounting?
Hard to see in the picture but I had to make a small L bracket to hold the motor
[Linked Image]image post
Re: Modern Bullitt build [Re: Keepat] #2905181
04/02/21 05:44 AM
04/02/21 05:44 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
That retract antenna is a nice find!
Pat this build is absolutely top notch. I can't get over how well executed every thing is on this build. The planning and workmanship is amazing.
Thanks for showing your work.
Re: Modern Bullitt build [Re: larry4406] #2905441
04/02/21 03:55 PM
04/02/21 03:55 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Larry, thanks for following along with this 7 year build and for your kind comments! The project is getting closer to the end and I’m looking forward to driving it soon!
Thank You!
Pat
Re: Modern Bullitt build [Re: Keepat] #2905523
04/02/21 06:22 PM
04/02/21 06:22 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
Thanks for the photo.
Re: Modern Bullitt build [Re: NITROUSN] #2905885
04/03/21 04:48 PM
04/03/21 04:48 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
So black it’s hard to see the grill frame to core support filler I made. I think it looks like something the factory would have made and not to custom looking.
Re: Modern Bullitt build [Re: Keepat] #2906497
04/04/21 07:15 PM
04/04/21 07:15 PM
Vancouver,BC
Mopar300F Offline
Mopar300F  Offline
Vancouver,BC
Will there be a separate switch for the Antennae of will it extend and retract when the radio is on/off?
My dad had a 68 New Yorker with power antennae and there was a switch on the dash near the radio.
Re: Modern Bullitt build [Re: Mopar300F] #2906562
04/04/21 09:10 PM
04/04/21 09:10 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
The new but original looking stereo has a power antenna output.
Pat
Re: Modern Bullitt build [Re: Keepat] #2909985
04/14/21 05:44 AM
04/14/21 05:44 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Finished the exhaust with the install of the S/S tips. Also installed the grill and finished the headlight wiring. Then the aluminum & carbon fiber bumper mounts, and valance. And started working on the front brake air intakes and mounted the horns under the headlights
Pat
[img]https://i.postimg.cc/rFf75Ygt/1-C32234-F-3777-4-A62-BFCC-CF171-EBC3-FE4.jpg[/img]
[img]https://i.postimg.cc/CK33zB7P/C077-A99-F-C2-F6-4760-B6-EF-CF6347703-DDD.jpg[/img]
Re: Modern Bullitt build [Re: Keepat] #2911356
04/17/21 02:59 PM
04/17/21 02:59 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
My LO horn is bad, looking for a replacement Prestolite horn. Please see picture for part numbers. I’m not concerned with date code but would like to have the same horn.
Pat
Re: Modern Bullitt build [Re: Keepat] #2911361
04/17/21 03:21 PM
04/17/21 03:21 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Just the grainy texture that is the issue? If the horn still works I'd just work the surface smooth with primer/sanding and repaint it.
Re: Modern Bullitt build [Re: Neil] #2911366
04/17/21 03:45 PM
04/17/21 03:45 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
No, does not work.
Re: Modern Bullitt build [Re: Keepat] #2911386
04/17/21 05:28 PM
04/17/21 05:28 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Sorry, my mistake. I see they sell reproduction horns in sets, but they appear to be the Spartan type.
Re: Modern Bullitt build [Re: Neil] #2911393
04/17/21 05:42 PM
04/17/21 05:42 PM
Vancouver,BC
Mopar300F Offline
Mopar300F  Offline
Vancouver,BC
I have read you can get a stuck horn working again by spraying WD40 into it.
Re: Modern Bullitt build [Re: Neil] #2911395
04/17/21 06:08 PM
04/17/21 06:08 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Yes I think classic industries sells them. But I really like to keep the same style horn as the old one that still works.
Thank you!
Re: Modern Bullitt build [Re: Mopar300F] #2911396
04/17/21 06:08 PM
04/17/21 06:08 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I will give that a try!
Thank you!
Pat
Re: Modern Bullitt build [Re: Keepat] #2911563
04/18/21 10:39 AM
04/18/21 10:39 AM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
The carbon fiber piece is sexy looking. Is that commercially available, or did you make it / have it made?
What is the motor in this picture?
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Modern Bullitt build [Re: DynoDave] #2911600
04/18/21 12:10 PM
04/18/21 12:10 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
It appears the horns can be serviced if you want to dig into it vs buying another. Might be possible to soak it in Evaporust to clean the contacts up as well?
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/566967/prestolite-horn-repair-101.html
Re: Modern Bullitt build [Re: DynoDave] #2911606
04/18/21 12:31 PM
04/18/21 12:31 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Replaced the vacuum canisters with electric motors to operate the headlight doors.
Re: Modern Bullitt build [Re: Neil] #2911607
04/18/21 12:35 PM
04/18/21 12:35 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Good stuff! Thanks for posting the link, I will give it a try!
Pat
Re: Modern Bullitt build [Re: Keepat] #2912636
04/20/21 09:40 PM
04/20/21 09:40 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Front brake air intakes are ready for paint just need to install the bumper and do any final adjustments to them.
Pat
