Page 3 of 5 1 2 3 4 5
Re: 426 wedge [Re: mr_340] #2905852
04/03/21 03:03 PM
04/03/21 03:03 PM
las vegas,nv
mopar muscle7271 Offline OP
las vegas,nv
Time you get that crank and pistons you can get custom pistons for about same the crank would cost.that be a stupid way to go as well.
Re: 426 wedge [Re: mopar muscle7271] #2906241
04/04/21 01:08 PM
04/04/21 01:08 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
True, if you don't want the extra 40+ cubic inches and 50 lb-ft of torque. Why get 478 CID instead of 431? Spend $1200 on a set of Diamonds instead. Your engine and money. Do WTFYW.
Floyd Lippencott IV
Re: 426 wedge [Re: mr_340] #2906314
04/04/21 02:42 PM
04/04/21 02:42 PM
las vegas,nv
las vegas,nv
I have 3 leads on new old stock 426 wedge pistons.much cheaper then custom ones to. If your not payin to do that my block.keep your mouth shut then,ill do what i want to it. I came here to look for 426 WEDGE PISTONS.not oh use 383 pistons which will give it 8:1 compression.there so down in the hole on cylinder walls.i bore to a 440 if went that way &cheaper then using 383 pistons route.
Re: 426 wedge [Re: mopar muscle7271] #2908285
04/09/21 02:42 AM
04/09/21 02:42 AM
las vegas,nv
las vegas,nv
I get 383 pistons will work but no one has any 426 wedge pistons on here they would sell?
Re: 426 wedge [Re: mopar muscle7271] #2908476
04/09/21 06:12 PM
04/09/21 06:12 PM
Long Island, New York
57Fury440 Offline
57Fury440  Offline
I have a set of 8 TRW pistons for a 426 wedge. They are used with about 3,000 miles on them. The part number is 2185F and they are 030 over. These were in one of my motors back in the early seventies. One of the rods spun a bearing and I had the connecting rod removed so I could replace it. I ended up getting a great deal on a 440 Six Pack motor and put the pistons aside. They are in my storage and I'll look for them in the next few days. I do not remember what the compression ratio of these are.
Re: 426 wedge [Re: 57Fury440] #2908514
04/09/21 08:44 PM
04/09/21 08:44 PM
las vegas,nv
las vegas,nv
Oh ok cool Im interested in them.lmk when you find them.
Re: 426 wedge [Re: mopar muscle7271] #2911023
04/16/21 05:30 PM
04/16/21 05:30 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Some CP Stocker pistons.
Floyd Lippencott IV
Re: 426 wedge [Re: mr_340] #2911302
04/17/21 11:54 AM
04/17/21 11:54 AM
las vegas,nv
las vegas,nv
Arent they a 075 over pistons?
Re: 426 wedge [Re: mopar muscle7271] #2911815
04/18/21 11:27 PM
04/18/21 11:27 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Only +.005" on my standard bore 440 block. I think it can be honed out to fit the pistons. Not sure which CP pistons they are. Al said there were no numbers stamped in the tops, like M14, etc. New stocker rings will cost a lot more than the pistons.
Floyd Lippencott IV
Re: 426 wedge [Re: mr_340] #2912153
04/20/21 12:37 AM
04/20/21 12:37 AM
las vegas,nv
las vegas,nv
Not lookin for a big bore pistons,030 would be good
Re: 426 wedge [Re: mopar muscle7271] #2913663
04/22/21 09:54 PM
04/22/21 09:54 PM
las vegas,nv
las vegas,nv
Have found some 426 wedge pistons old school mickey pistons ones brand new but they take a .984 wirst pin, which is the small block wirst pin size, what kind of pin or bushing to make them work with a big block stock rods?
Re: 426 wedge [Re: mopar muscle7271] #2913678
04/22/21 10:19 PM
04/22/21 10:19 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Options ? ... bore the pin hole ... or bush the rods
Re: 426 wedge [Re: dOoC] #2913682
04/22/21 10:31 PM
04/22/21 10:31 PM
las vegas,nv
las vegas,nv
You can bush rods form a 1.904 to a .984?
Re: 426 wedge [Re: mopar muscle7271] #2913688
04/22/21 10:42 PM
04/22/21 10:42 PM
You can't make them work with those pins safely down
Maybe you can have the pistons converted, machined, for stock BB pins scope twocents
Re: 426 wedge [Re: mopar muscle7271] #2913692
04/22/21 10:49 PM
04/22/21 10:49 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
1.904 eek
Re: 426 wedge [Re: dOoC] #2913703
04/22/21 11:10 PM
04/22/21 11:10 PM
las vegas,nv
las vegas,nv
That's the stock size of a wirst pin for a big block mopar engine
Re: 426 wedge [Re: mopar muscle7271] #2913727
04/23/21 12:17 AM
04/23/21 12:17 AM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
Better check aGaIn .... tsk grin
Re: 426 wedge [Re: dOoC] #2913729
04/23/21 12:30 AM
04/23/21 12:30 AM
las vegas,nv
las vegas,nv
Couldnt they be machined to a .990 wirst pin size? Not much from a .984 then l could get reducer bushings or rods for the .990 size
Re: 426 wedge [Re: mopar muscle7271] #2914109
04/23/21 09:28 PM
04/23/21 09:28 PM
Try calling both Jahns, if they are still in business and or Ross pistons and see if they will remachine the wrist pin hole in those old M/T pistons for you.
Mickey Thompson always had vendors make his parts, he didn't own the company that made them for him,
Maybe even try Crower on fixing them for you scope
Re: 426 wedge [Re: Cab_Burge] #2914174
04/23/21 11:58 PM
04/23/21 11:58 PM
las vegas,nv
las vegas,nv
Oh ok I can try and call a few piston shops up.jahns is called je pistons now
