Hemi storage cradle / dolly plans? #2910488
04/15/21 01:37 PM
04/15/21 01:37 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
Hi, does anyone have a blueprint to build a little dolly or cradle for storing Gen 2 hemis? I used to have one that bolted onto the motor mount holes and the bell housing area. It would be nice if it left the bellhousing flange open to put a transmission on it if needed.
Thanks, Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Hemi storage cradle / dolly plans? [Re: Hemi_Joel] #2910491
04/15/21 01:54 PM
04/15/21 01:54 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Just use an old semi tire. I’m sure you have a few laying around.
My engine cradle just mounts on the front side of the bell housing face, so I could have the bell indexed.
69 GTX 68 Road Runner
Re: Hemi storage cradle / dolly plans? [Re: JERICOGTX] #2910492
04/15/21 01:58 PM
04/15/21 01:58 PM
Minnesota
Minnesota
I used to have a nice one I got from Lofgren, but I don't know what happened to it. It would be nice to get a good design, set up the chop saw and the welder, and knock out a few assembly line style.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Hemi storage cradle / dolly plans? [Re: JERICOGTX] #2910493
04/15/21 02:00 PM
04/15/21 02:00 PM
Minnesota
Minnesota
Something a little more precise and steady... up
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Hemi storage cradle / dolly plans? [Re: Hemi_Joel] #2910494
04/15/21 02:03 PM
04/15/21 02:03 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I'd send you a picture of mine, but it is at Harlans at this time.
Re: Hemi storage cradle / dolly plans? [Re: JERICOGTX] #2910495
04/15/21 02:07 PM
04/15/21 02:07 PM
Minnesota
Minnesota
OK, I'll check back with you on that in 6 months. ozbbq
Wedge and Hemi are different anyway.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Hemi storage cradle / dolly plans? [Re: Hemi_Joel] #2910497
04/15/21 02:11 PM
04/15/21 02:11 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Yes, but easy to do. Just bolts up differently, just like my INDY block.
Re: Hemi storage cradle / dolly plans? [Re: Hemi_Joel] #2910498
04/15/21 02:12 PM
04/15/21 02:12 PM
AndyF Offline
AndyF  Offline
I used to make them but I stopped. Bob Mazzolini was making Hemi dollies but not sure if he still is.
Re: Hemi storage cradle / dolly plans? [Re: AndyF] #2910501
04/15/21 02:22 PM
04/15/21 02:22 PM
Minnesota
Minnesota
If I design one, I'll make to fit onto a $15 Harbor Freight furniture dolly. Cheaper than buying caster wheels, and can be set in a truck bed without the wheels for stability.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Hemi storage cradle / dolly plans? [Re: Hemi_Joel] #2910511
04/15/21 02:31 PM
04/15/21 02:31 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Harbor Freight, and stability do not go hand in hand. LOL.
Re: Hemi storage cradle / dolly plans? [Re: JERICOGTX] #2910524
04/15/21 03:05 PM
04/15/21 03:05 PM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
Im sure its there somewhere. Look again
Re: Hemi storage cradle / dolly plans? [Re: Hemi_Joel] #2910529
04/15/21 03:36 PM
04/15/21 03:36 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
What I use for an engine dolly on old engines (usually short blocks) are the Harbor Freight car dollies.
They don't roll very well with a car on them, but do just fine with an engine.
They could have brackets welded to them to bolt an engine on them like AndyF's pic.
They would be strong with less fabrication needed than building from scratch, you just need brackets to bolt the engine in place. twocents
Re: Hemi storage cradle / dolly plans? [Re: SNK-EYZ] #2910571
04/15/21 05:03 PM
04/15/21 05:03 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Here's mine, no prints but tape measure and a chop saw will almost get you there.
Also have seen more than one grocery cart sacrificed for the cause....
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Hemi storage cradle / dolly plans? [Re: W.I.N. Racing] #2910585
04/15/21 05:29 PM
04/15/21 05:29 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
I think this is the one that Summit sells.
[Linked Image]IMG_1921 by Greg Ault, on Flickr
Re: Hemi storage cradle / dolly plans? [Re: Hemi_Joel] #2910587
04/15/21 05:42 PM
04/15/21 05:42 PM
AndyF Offline
AndyF  Offline
How about one of each flavor?
Re: Hemi storage cradle / dolly plans? [Re: AndyF] #2910723
04/15/21 10:09 PM
04/15/21 10:09 PM
Steel caster roller roll way better than the rubber tires one due, at least in my shop shruggy
Re: Hemi storage cradle / dolly plans? [Re: Cab_Burge] #2910796
04/16/21 07:20 AM
04/16/21 07:20 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
I found this one on e-bay - its very well built
www.rcrmetalfab.com 1-219-808-6268
Re: Hemi storage cradle / dolly plans? [Re: Hemi_Joel] #2910818
04/16/21 09:00 AM
04/16/21 09:00 AM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
I haven't had success going that route. I built six dollies using the Harbor Freight 1000# furniture dollies. There are two problems. The first is the casters, they are too small in diameter and of poor quality. With the weight of a fully dressed out 440 you can barely move it as they catch on every minor defect in the floor. After you have moved them around for a while, loaded all the time, the casters start deteriorating making it harder to push. The second is the dolly itself, I made a box on top of the dolly that the oil pan fits into. Even with this additional reinforcement, with the constant load of an engine the dolly starts to sag.
The next one is going to be steel square tube and at least 3" diameter casters.
Re: Hemi storage cradle / dolly plans? [Re: 6PakBee] #2910903
04/16/21 11:57 AM
04/16/21 11:57 AM
AndyF Offline
AndyF  Offline
Exactly. I tried a bunch of different designs when I first started building engine dollies and ended up with a steel frame and 5 inch poly casters. Nothing else held up or worked for very long.
Re: Hemi storage cradle / dolly plans? [Re: AndyF] #2911279
04/17/21 11:09 AM
04/17/21 11:09 AM
New York, USA
Chargerfan68 Offline
New York, USA
I’ve built a few out of 1-1/2” square .083” wall. They are plenty beefy. Some i used the factoru munt brackets welded to the cradle, and others i just got some 3/8” ppipe welded to arm supports for ft mounts.
B8948F6A-B23F-402D-A263-BC0383340994.jpeg0CFBA3C5-5190-424D-A395-D448CB925242.jpeg47A3EEC1-E6CF-4D76-9909-A071097B8324.jpeg
