Disc Brake Conversion Question
#2909687
04/13/21 08:08 AM
04/13/21 08:08 AM
Posts: 4,288 Danville, NH
Mopar_Mike
Danville, NH
Converting my manual drum 67 B-body to PDB. Can I use the same brake metering block that is attached to the frame rail under the master cylinder? I know I need an additional metering block for under the drivers seat rail for the disc brakes. Thanks.
RS23L7 4-Speed
Re: Disc Brake Conversion Question
[Re: 71birdJ68]
#2909694
04/13/21 08:58 AM
04/13/21 08:58 AM
Posts: 22,727 Bitopia
jcc
Bitopia
That's not a metering block that you have, it's just a distribution block. Yes, you can do like you said, you can keep it and add a proportioning valve for the back brakes. Don't forget that you also need a different master cylinder and all the stuff that goes with it and the booster. Also when you get done the pedal will be close to the floor and this is normal. That maybe the case, but not the goal, care to explain?
[Re: jcc]
#2909716
04/13/21 09:47 AM
04/13/21 09:47 AM
Posts: 12,282 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
It's may be, jcc. Not maybe. There is a difference.
Master, again and still
[Re: poorboy]
#2912813
04/21/21 11:10 AM
04/21/21 11:10 AM
Mopar_Mike
Danville, NH
So installed the PDB set up and sure enough the pedal is lower to the floor. I think there will be enough "pedal" for it to work fine, but most likely will not line up with the clutch pedal, but the car is still in restoration mode. The car is a 4-speed car and the above explanation makes a lot of sense. Given that, would it be safe to assume that a factory 4-spd car that was factory PDB would have the hole in the pedal higher? Thinking that maybe 4-spd pedals from a PDB would make the pedal higher.
RS23L7 4-Speed
[Re: Mopar_Mike]
#2912839
04/21/21 12:00 PM
04/21/21 12:00 PM
Posts: 19,624 north of coder
moparx
the higher the hole for attaching the push rod to is to the pivot point, the bigger the pedal ratio is. in other words, the high attaching hole is for manual brakes. think 6:1. power brakes always have a lower ratio, think 4:1, therefore the hole is farther away from the pivot point of the pedal.
