Anyone run synthetic in their 727?
#290963
04/17/09 09:36 AM
04/17/09 09:36 AM
Posts: 226 lino lakes,MN
onebaddakota
lino lakes,MN
Just wondering if it's worth it. I read an old article about switching all fluids(tranny,rear engine) over to synthetic and picking up a tenth. Tom
10.56 at 125.6, with a 1.43 60 ft.
E85, Hyd. Roller 410 magnum,full exhaust, 3500 race weight.
Re: Anyone run synthetic in their 727?
[Re: hemi471]
#290971
04/17/09 07:02 PM
04/17/09 07:02 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
Depends who you ask, the old-timers will say to run cheap type F, I use Amsoil Super Shift.
i am running the this also [the super shift]
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Post deleted by Defbob
[Re: KatFysh]
#290974
04/18/09 02:51 PM
04/18/09 02:51 PM
#290976
04/18/09 10:54 PM
04/18/09 10:54 PM
A prominent Torqueflite builder on this board told me he doesn't recommend synthetic trans fluid because its too slippery, and will glaze the clutches over time.
thats wrong, a premier tranny builder showed me clutches with ATF+4 synthetic compared to a conventional tranny fluid, same car & same trans., different fluids, ATF+4 clutches looked like new and the fluid was nice and red, the cnventional fluid was a little brown and clutches were worn. i now use ATF+4 in my aluminum drum low gear set 727 and the clutches look like brand new and 4 seasons,and going strong.
#290977
04/19/09 09:08 AM
04/19/09 09:08 AM
Posts: 5,991 Anoka County, MN
Leigh
Anoka County, MN
Apples to oranges. The test would have to be of a controlled nature. i.e., same clearances, type and number of discs, same valve body, same car, same launch, same driver, same driving style and same service interval. I highly doubt this has been documented, thus, to quote a board member, "anecdotal".
#290978
04/19/09 09:13 AM
04/19/09 09:13 AM
Posts: 30,474 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
And me-thimks more importantly .... the front band.
