Air shifter? #290914
04/17/09 07:10 AM
04/17/09 07:10 AM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
Hi guys
Please give advice, is 350 and above dollars worth to spend on air shifter like http://www.jegs.com/p/Dedenbear/745785/10002/-1 ?
Most Iam interested in what advance it gives me?
Thanks for answers
Outlaw Plymouth Valiant R5/P7 Powered by Liuzzo Racing COMP Performance Group dealer in Baltic Premium Performance
Re: Air shifter? [Re: Georg] #290915
04/17/09 09:17 AM
04/17/09 09:17 AM
PA
moparacer Offline
moparacer  Offline
PA
Are you bracket racing and running the electronics class?
If so, you need every consistency advantage you can get in super pro and a air shifter is a must nowadays.
I have that exact same kit I used in my cars when I run super pro. Works great just make sure you dont let the bottle get low.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Air shifter? [Re: Georg] #290916
04/17/09 09:38 AM
04/17/09 09:38 AM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
I really like my Dedenbear air shifter.
don't forget to order the correct gate plate for your conversion.
Re: Air shifter? [Re: Rodney] #290917
04/17/09 09:55 AM
04/17/09 09:55 AM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
So consistency is only advance? If so then I think I dont need this system? Iam going to race in heads-up class
Re: Air shifter? [Re: Georg] #290918
04/17/09 10:19 AM
04/17/09 10:19 AM
PA
ajcasini Offline
ajcasini  Offline
PA
The nice thing the air shifter does for is takes one more thing out of the equation. You know it will always shift at X. Whether X be time or RPM. This is an advantage in any class in my opinion.
AJ
Re: Air shifter? [Re: Georg] #290919
04/17/09 10:51 AM
04/17/09 10:51 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
No.......some cars are sensitive to shift points.
Shifting at optimum RPM will lower ET if, you
fall into this catagory.
Re: Air shifter? [Re: S/ST 3040] #290920
04/17/09 02:08 PM
04/17/09 02:08 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
if you don't already have co2 in the car I would go electric shifter for sure...
I just happen to have one for sale in the race section!
Re: Air shifter? [Re: MegaDart] #290921
04/18/09 04:41 AM
04/18/09 04:41 AM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
Hi
What brand and part code is this electric shifter?
And what price you want for that piece?
Do you also ship it worldwide?
Georg
Re: Air shifter? [Re: Georg] #290922
04/19/09 04:17 AM
04/19/09 04:17 AM
Finland
Hessu Offline
Hessu  Offline
Finland
If you already have ratchet shifter it`s not difficult to built air shifter.
Here is mine. I use summit rpm activation switch and compressed air to drive it. It`s working great.
